haubstr Posted October 4, 2008 Report Share Posted October 4, 2008 I was searching for the head gasket for an L20B that has been bored out 40 over. I set the stock head gasket on it and it is to small. Are people using head gaskets from the Z20 or Z22's? Thanks Quote Link to comment
datzenmike Posted October 4, 2008 Report Share Posted October 4, 2008 0.040" is close to 1mm over, or 86mm bore. The Z22 gasket is 87mm and would work if you graft the very front of the old L gasket onto it and a small dab of rtv. Quote Link to comment
Jason Posted October 5, 2008 Report Share Posted October 5, 2008 I think you can get a Nismo headgasket in that size too. Quote Link to comment
hang_510 Posted October 7, 2008 Report Share Posted October 7, 2008 nismo is 88.5mm (and getting hard to locate) wolf creek racing was the last place i found the had them Quote Link to comment
Clearalbino Posted October 7, 2008 Report Share Posted October 7, 2008 I also had a Nismo 88.5 for sale for $75 shipped Quote Link to comment
haubstr Posted October 7, 2008 Author Report Share Posted October 7, 2008 This is on the Wolf Creek Racing site: 4 Cylinder Competition Head Gasket - NOS Nissan Motorsports 11044-A7651 ($79 list)..L-series..........................$60 That is the 88.5mm head gasket. Is 88.5 too big for the 86mm bore? Thanks Quote Link to comment
hang_510 Posted October 7, 2008 Report Share Posted October 7, 2008 correct part# it SHOULD be fine(not racing it are you?). dont think you have much of a choice either :mellow: Quote Link to comment
yello620 Posted October 8, 2008 Report Share Posted October 8, 2008 So which head gasket is being used on the big bore LZ2.3 motors? Jason Quote Link to comment
datzenmike Posted October 8, 2008 Report Share Posted October 8, 2008 Probably the 89mm Z24 gasket. Quote Link to comment
haubstr Posted October 8, 2008 Author Report Share Posted October 8, 2008 This is my dad's truck so I don't think he will be racing. These are low compression pistons but he will be using a turbo setup that will put out around 5 PSI or so. Thanks Quote Link to comment
