heywier427 Posted April 26, 2015 Report Share Posted April 26, 2015 How do you determine/identify the differences between the stock 510 steering box, and the b210 unit? Thanks. Quote Link to comment
datzenmike Posted April 26, 2015 Report Share Posted April 26, 2015 510 There are 3 bolts holding the cover on the rear column spline input The top of the box has a round 3 bolt cover with the adjustment screw and filler hole on it. B-210 The cover on the rear column spline input has 4 bolts holding the shims and seal. The top of the box has a rectangular 4 bolt cover with the adjustment screw and filler hole on it. HLA10 similar to the B-210 and shares internal parts. Both have different pitman arms, what the difference is, other than the part umber, I don't know Quote Link to comment
heywier427 Posted April 26, 2015 Author Report Share Posted April 26, 2015 Thank you. Have a line on one cheap, but wanted to make sure I didn't already have one! Thanks. Quote Link to comment
ggzilla Posted April 27, 2015 Report Share Posted April 27, 2015 Also, the B210 boxes are prone to wearing out. Quote Link to comment
