DanielC Posted March 24, 2015 Report Share Posted March 24, 2015 Will the starter off a Z-20 a Z-22 or a Z-24 engine work on a L engine? Quote Link to comment
datsunaholic Posted March 24, 2015 Report Share Posted March 24, 2015 Yes, though the solenoid clocks a little different. I had issues with it touching the clutch line on one car, but don't remember which. 1 Quote Link to comment
datzenmike Posted March 24, 2015 Report Share Posted March 24, 2015 The solenoid does not clear the L series dip stick tube. I bent mine.... then can't get the stick in or out. Had to make a new flexible thin strip dip stick from a chev or ford or something. Z series is clocked to the left while the L block is clocked to the right and they are too close. L series starters fit the Z series engines no problem. 1 Quote Link to comment
