datzenmike Posted August 1, 2015 Report Share Posted August 1, 2015 The Z24 head exhaust ports can be modified to fit the KA24E turbo exhaust manifold, yes. Get the KA gasket and set on the Z head. Spray paint the ports, take the gasket off. Anything painted can be ground away (within reason) 1 Quote Link to comment
xHighOctanex Posted August 10, 2015 Author Report Share Posted August 10, 2015 The Z24 head exhaust ports can be modified to fit the KA24E turbo exhaust manifold, yes. Get the KA gasket and set on the Z head. Spray paint the ports, take the gasket off. Anything painted can be ground away (within reason) I might try that, but I was talking about with the the KA I'm building, do I have to worry about anything when getting a turbo manifold n what not? Quote Link to comment
xHighOctanex Posted August 10, 2015 Author Report Share Posted August 10, 2015 I'm finally at the point to where I am going to start ordering stuff to get the motor put back together, I have found a few sites to buy stuff, but is there any particular sites you guys use to order your stuff for KAs? I been looking on RealStreet and 240sxmotoring. Hoping to order my bearings tomorrow, and after I get a little more money coming in get rings and gaskets. Hoping to have the bottom end together somewhere around mid September. Quote Link to comment
datzenmike Posted August 11, 2015 Report Share Posted August 11, 2015 I might try that, but I was talking about with the the KA I'm building, do I have to worry about anything when getting a turbo manifold n what not? Trucks have a steering box at the front with a long steering column and torsion bars on that side of the engine. At least it doesn't have a strut tower. Quote Link to comment
xHighOctanex Posted August 12, 2015 Author Report Share Posted August 12, 2015 Trucks have a steering box at the front with a long steering column and torsion bars on that side of the engine. At least it doesn't have a strut tower. Hey my friend just got me a hookup on a weber carb for 75$, I was going to order my turbo rebuild kit but I'm thinkin about the carb first since my stock one is getting worse and worse, anything I should know about the webers? Quote Link to comment
xHighOctanex Posted August 12, 2015 Author Report Share Posted August 12, 2015 The truck as it sits right now, finishing the fenders still. (Real comic pages) Quote Link to comment
Rhino13 Posted August 13, 2015 Report Share Posted August 13, 2015 First off, you'll need a Weber adapter plate. If the Weber is old, make sure you wiggle the throttle shafts to see if there's play. If there is, don't get it, it'll have vacuum leaks from there. If not, get a rebuild kit and install all the new hardware, delete most of your vacuum lines other than vacuum advance, and throw it on. On the z24, you'll need to slightly bend the hard fuel line that comes up between the intake manifold. To bend it, stick a smaller screwdriver or something of the sort down into it and slowly pull on it, don't use pliers or you could make a bend in the line which will pinch it and possibly crack it. 1 Quote Link to comment
xHighOctanex Posted August 13, 2015 Author Report Share Posted August 13, 2015 First off, you'll need a Weber adapter plate. If the Weber is old, make sure you wiggle the throttle shafts to see if there's play. If there is, don't get it, it'll have vacuum leaks from there. If not, get a rebuild kit and install all the new hardware, delete most of your vacuum lines other than vacuum advance, and throw it on. On the z24, you'll need to slightly bend the hard fuel line that comes up between the intake manifold. To bend it, stick a smaller screwdriver or something of the sort down into it and slowly pull on it, don't use pliers or you could make a bend in the line which will pinch it and possibly crackh Alright, I'm hopefully gonna see it in the next few days. If it has any problems I'm just gonna go ahead and buy my turbo rebuild kit :thumbup: Quote Link to comment
xHighOctanex Posted October 8, 2015 Author Report Share Posted October 8, 2015 Got some 18s on the truck now, they suit it really well. Leaving the fenders flared so I have the option of throwing the 15s on when I eventually get to actually slide the darn thing. Also thinking about just converting the Z to fuel injection and then doing the turbo on this motor for now, getting the trans, getting the driveshaft made, and welding the diff. This way I should have a good base to learn to slide before I throw a higher power KA in and and up smashing it into a wall. Also the truck passed smog last week...so that's cool. Quote Link to comment
xHighOctanex Posted October 25, 2015 Author Report Share Posted October 25, 2015 Drivers side window regulator gave out tonight so gonna see if I can get one before it rains. Worst timing for this. Other than that, I put a new glovebox door on (mine has been broken for almost a year), got a new speedocable, plastidipping my rims, and last but definitely not least I'm doing my coils soon. A guy in town knows how to do it and said he would show me if I bought the parts so can't wait. Quote Link to comment
xHighOctanex Posted November 11, 2015 Author Report Share Posted November 11, 2015 Today marks the day I have FINALLY bought the rod and main bearings for the KA, progress friends, progress. 2 Quote Link to comment
xHighOctanex Posted December 9, 2015 Author Report Share Posted December 9, 2015 So I got my second 720, an 84 extended or kc just know it's got the back space, 4x4 on I think 33s. The motor is out and at my house right now, doesn't run on all 4 cylinders, has a snapped torsion bar, and some kids at the high school smashed the windshield. I priced out everything to get it good and ready it's about 450 for the torsion bar, windshield installed, new pistons, rings, bearings, and a whole gasket kit, hoping the head is fine and that the rings are just fudged. Worst case I'll pull the motor from my 85 and throw it in the truck. Pretty worth it for a free truck. Mark that Don as 2 free 720s Quote Link to comment
xHighOctanex Posted December 11, 2015 Author Report Share Posted December 11, 2015 Windshield, Window regulator, Torsion Bar Quote Link to comment
