Low73620 Posted March 3, 2015 Report Share Posted March 3, 2015 Hey all! What here is what i have. I have a 73 620 with a 4speed, hoping to swap with this unknown Nissan 5speed. I know i have some issues to work out. but here is my main concern... After comparing the the 2 side by side i noticed that the input shaft is slightly different, seems the pilot shaft is longer on the 4speed. 4speed 5speed Quote Link to comment
datzenmike Posted March 4, 2015 Report Share Posted March 4, 2015 That is an L series FS5W71B 5 speed made after '79. With a neutral switch for carb based emissions, it can only be from the '80 720 2wd truck. The top gear switch (only used on California emissions vehicles) means it's from ... California.It will be too long for your '73 to just drop in. You will need to shorten your present driveshaft by about 5.5 inches OR find the front driveshaft from a '74-'79 620 truck which had this length transmission. This will be cheaper than having yours shortened. The part below is your release bearing and collar. The collar (top part) holds the bearing (round bottom part) Make damn sure that you use your release bearing and collar that was on your four speed. Do NOT us the one that is on the 5 speed now. Have the bearing pressed off and a new bearing pressed on. The bearing is a high wear item and not easy to service if it should start to make noise so put a new one on while it is out. The '73 620 truck release bearing is # 30502-21000 and about $40 at the dealer so use this number and have NAPA cross reference one. The bearing looks (more or less) like this... Quote Link to comment
Low73620 Posted March 4, 2015 Author Report Share Posted March 4, 2015 Looks like I'm in the market for a front half drive shaft. Thanks Mike.. I saw in few of your posts that you repaired your drive shaft center support isolator bushing, Do you have any pics? Thanks again Quote Link to comment
datzenmike Posted March 4, 2015 Report Share Posted March 4, 2015 No pics, I thought it was temp. Just think of a thick belt wrapped around the driveshaft and tightened down.. Quote Link to comment
MikeRL411 Posted March 5, 2015 Report Share Posted March 5, 2015 Old vehicle plus ingenuity equals a long and satisfactory life span. Quote Link to comment
wayno Posted March 5, 2015 Report Share Posted March 5, 2015 I just made one of these temporary fixes yesterday, I used some air conditioning hose and some zip ties. 1 Quote Link to comment
datzenmike Posted March 5, 2015 Report Share Posted March 5, 2015 That's ratsun right there... Quote Link to comment
Low73620 Posted March 6, 2015 Author Report Share Posted March 6, 2015 Nice! Job on the Isolator! I've found a front half drive shaft, should be getting it today. Looks like i'll have this thing back on the road sooner than I thought. I miss the little bastard.. Quote Link to comment
