Recon716 Posted December 30, 2014 Report Share Posted December 30, 2014 Okay, I have a 73 L16 with a Weber carb. I just replaced the electric choke and topped off the oil. But for what ever reason, it likes to idle at around 1800 when its cold, and 2700 when its hot. Carb is about 6 months old, fuel pump has been replaced with a Mr Gasket universal. Looked at my choke and its set right, and the high idle cam is moving on and off the screw. What do??? Quote Link to comment
datzenmike Posted December 30, 2014 Report Share Posted December 30, 2014 620 right? Fast idle causes.... Choke on or part on Fast idle cam engaged or stuck .... even though checked I included for the sake of others. Throttle cable too tight can't return any lower. Primary barrel prevented from closing by accelerator pump linkage (or other) Secondary barrel not fully closing. Fast idle screw adjusted too high. Not familiar with the weber. Could be a wrong air bleed/mixture screw/jet??? who knows. Can you push the throttle closed by hand? If throttle is bottomed all the way, you must have both a vacuum leak and over rich condition. The idle screw is probably adjusted to compensate for the leak and it revs up. Spray carb cleaner around the carb base and adapter. Adapters will crack from over tightening. If idle quality changes..... Fuel pressure shouldn't be much above 3 to 3.5 PSI. Webers are very sensitive to over pressure and will flood. 1 Quote Link to comment
Doctor510 Posted December 30, 2014 Report Share Posted December 30, 2014 Is it a 32/36 DGEV? You replaced the electric choke/why? Did you replace it and set it correctly? Mike nailed all the other stuff. Quote Link to comment
Recon716 Posted December 30, 2014 Author Report Share Posted December 30, 2014 Mike nailed it. 32/36. Turns out I installed the choke improperly and the high idle screw was just too tight after adjusting the linkage. Tested the fuel pressure and its putting out just under 4. But I replaced the choke because i had a small oil fire and melted the casing. I'm going to be looking at a new profession shortly. 1 Quote Link to comment
shacks510 Posted December 30, 2014 Report Share Posted December 30, 2014 Did you use a new manifold gasket? There could be a vacuum leak from there. Best to replace a gasket once it's disturbed by taking things apart. Quote Link to comment
