mhub91 Posted December 19, 2014 Report Share Posted December 19, 2014 Blew a headgasket in my "new" '78 620. I've got an A87 closed chamber head in good condition and plan on throwing it on (why not?) Wondering if i need to run a cooler or hotter plug than what the W58 runs? Any other info I should know? Thanks. Quote Link to comment
datzenmike Posted December 19, 2014 Report Share Posted December 19, 2014 Shouldn't have to and here's why. The design of the closed chamber head is such that the combustion chamber is much smaller than the diameter of the piston below it. This means that at TDC there is only the thickness of the head gasket between it and the head surface around the base of the combustion chamber. (not strictly true as the L20B has a dished piston and this would apply more to a flattop piston) The air in the cylinder is pinched out from between the piston and the underside of the head and this induces beneficial turbulence and swirl that further mixes the fuel and air. The mixing prevents lean and rich areas and it will burn more efficiently. Lean areas will run hotter as there is less cooler atomized fuel to absorb heat. Rich areas will burn incompletely and leave soot. Turbulence will cool the piston top and all of the combustion chamber including hot spots like the spark plugs, and exhaust valves. A closed chamber head is much less prone to heat caused detonation that an open chamber head with the same compression. You know that only the W58 has round exhaust ports.right? An L16/18 exhaust manifold is known as the cast iron header. Quote Link to comment
67_1600 Posted December 19, 2014 Report Share Posted December 19, 2014 From what I recall, you W58 head has round ports but the A87 has square/rectangular ports. At the very minimum you'll need a matching manifold. I don't think plugs will matter at all. Quote Link to comment
mhub91 Posted December 20, 2014 Author Report Share Posted December 20, 2014 I am "upgrading" to a non-smog manifold setup. Thank you for the help! Quote Link to comment
datzenmike Posted December 20, 2014 Report Share Posted December 20, 2014 The 'non smog' would be for an L16 or very early L18 and they have smaller diameter runners than the W-58. Not always a bad thing but all L20B engines use the larger. Quote Link to comment
