allen dodson Posted September 20, 2008 Report Share Posted September 20, 2008 Thinking of buying a mild street cam for my L16. Its basically all stock except dual carbs. How easy is it to install a camshaft? Is it worth the money and time? Its going in a 521 pickup with stock rearend gears and the stock 4 speed. Quote Link to comment
datzenmike Posted September 20, 2008 Report Share Posted September 20, 2008 Pull the cam, rockers and lash pads, etc from any L20B head. 248 duration and 0.413" lift. Same specs as the L16SSS cam. Cheaper too. Easy to do with a few wrenches and a couple of hours. Quote Link to comment
moparvwfreak Posted September 20, 2008 Report Share Posted September 20, 2008 it sounds like it should be an afternoon job if all theparts are handy. couple extra hours if you have to go to the yard and yank one. Quote Link to comment
datsunfish Posted September 20, 2008 Report Share Posted September 20, 2008 L20b cam is a very mild upgrade. I run a 450 regrind on my l16 and it still sucks because the L16 is very gutless for how heavy it is. But it runs great. Kinda lumpy but very responsive and revs up past 7k. Great for passing on the highway. Quote Link to comment
moparvwfreak Posted September 20, 2008 Report Share Posted September 20, 2008 hmmm.... i could use something like that in my truck. Quote Link to comment
datzenmike Posted September 20, 2008 Report Share Posted September 20, 2008 L20b cam is a very mild upgrade. I run a 450 regrind on my l16 and it still sucks because the L16 is very gutless for how heavy it is. But it runs great. Kinda lumpy but very responsive and revs up past 7k. Great for passing on the highway. Agreed, but he said 'mild' lol. Was thinking he might have an old L20B head lying about so zero investment of money. Power means revving it up. Opening valves sooner and closing later. Opening valved further. Stronger springs. Larger valves. How mild???:D Quote Link to comment
allen dodson Posted September 20, 2008 Author Report Share Posted September 20, 2008 Oh buy the not that it matters much but the 521 also has a mallory electronic dist, comp cams and i wish i could put a link here for it has two camshafts iam interested in. I think its part number 79-123-4. Quote Link to comment
Phlebmaster Posted September 21, 2008 Report Share Posted September 21, 2008 I have an L-16... I started with the stock l-16 cam. I switched to the stock l-20 cam and it was an improvement, but only slightly. I then put in a mystery regrind cam and WoW! You can here it run in my project thread, I like the comp cam the best. Quote Link to comment
J.C_620 Posted September 22, 2008 Report Share Posted September 22, 2008 Thats a good cam it is what i have in my truck but if i were to do it all over again i would go with the 81-123-4? not sure as they make 3 diffrent grinds for the L motor Quote Link to comment
J.C_620 Posted September 22, 2008 Report Share Posted September 22, 2008 79-123-4 = 214 duration 420 lift with 110 degree centerline stock springs and lash pads smooth idle good power between 2500 and 5000 real easy to chirp the tires shifting into 3rd Quote Link to comment
Datsunny Posted September 23, 2008 Report Share Posted September 23, 2008 so where can i find the performance cams? Quote Link to comment
