Odd Oil Leak @ Oil Filter
jfbrink
Hey,
Last weekend, as I was parking, I noticed that the J13 in my '66 was almost pouring oil out the side. When I got in there, it looked like the oil was coming out around the rear and lower oil filter housing bolts. I pulled the housing, cleaned it up (making sure the springy ball was clean and free), cleaned the mounting faces and put it back on with a new gasket (dry, no sealant). New filter, new old-car oil and after about 30 miles, it's leaking again, from around the bolts, albeit much more slowly.
I can't help thinking this is some sort of more complex / serious problem, like a blockage causing excess pressure or something.
Has anyone had something like this happen?
Best,
Jesse.
  • Replies 4
Pressure is regulated at the pump. A blockage would only make the pressure rise to the maximum setting on the by pass spring.
Having said that... I did once split the oil filter can twice before figuring the pump relief valve was jammed with a piece of casting. This doesn't seem to be the cause here.
