bk whitest Posted August 12, 2014 Report Share Posted August 12, 2014 just wondering has anyone tried putting coilovers on the front of a 720 pick up ? woould deffenitly be interested the rear would be another story lol Quote Link to comment
datzenmike Posted August 12, 2014 Report Share Posted August 12, 2014 Won't make the same mistake twice. The 720 already has a torsion bar suspension that works well and coil over shocks is a radical change, so unless there is a clear advantage to doing so, I wouldn't bother. What do you hope to get out of this? 1 Quote Link to comment
bk whitest Posted August 12, 2014 Author Report Share Posted August 12, 2014 a more modern suspesion still learning te old girls Quote Link to comment
datzenmike Posted August 12, 2014 Report Share Posted August 12, 2014 There are more modern suspensions (as in newer) but coils spring, leaf springs and torsion bars have been around for ever. Nothing new about coils. Quote Link to comment
Justin Berni Posted August 12, 2014 Report Share Posted August 12, 2014 The only advantage I see to coilovers would be that you can go as low as you want and still maintain good ride quality. Quote Link to comment
datzenmike Posted August 12, 2014 Report Share Posted August 12, 2014 Don't think so. The max low is when the bump stops bottom out... and you can do that with the stock torsion bars. Quote Link to comment
Justin Berni Posted August 12, 2014 Report Share Posted August 12, 2014 Don't think so. The max low is when the bump stops bottom out... and you can do that with the stock torsion bars. I guess I didn't think that out too far than. But still, I've had mine maxed to the bump stops and the ride quality wasn't as good as any lowered car on coilovers that I've been in. So even if you can't go any lower, you could have much better ride quality, right? I still don't think it's worth the hassle tho, just for a comfy ride haha. Quote Link to comment
datzenmike Posted August 12, 2014 Report Share Posted August 12, 2014 A lowered car probably had some suspension movement left to absorb the bumps while your truck was solidly on or near the stops. You could try trimming the stops to allow the truck more movement or even raise it up slightly. Running a minimum air pressure in the tires might help too.. Quote Link to comment
thisismatt Posted August 12, 2014 Report Share Posted August 12, 2014 There's no practical difference between a coil and a torsion bar when it comes to function, all else being equal. You're more likely running into issues with travel limits, shock limits, or shock choice. Advantage of coils is you have more options for spring rates. Quote Link to comment
