How to Make (Better than OEM) Grille Clips From Crap in Your Garage
floyd17
236D11C4-9985-471F-B8D0-2B7861C15017_zps
What you need:
Zipties
Scissors (or a knife)
Adhesive Foam (optional)
Washers (make sure zip tie fits through eye of washer, but does NOT allow the lock on the end to pass through)
(optional pre-mounting of rattle reduction foam): cut a square of adhesive foam (small enough to fit under the mounting tongue of the grille unlike I did. I later trimmed it.) and place it over the mounting hole on the frame. puncture it with a knife or scissors or any sharp object.
DE58BCE1-6694-45BC-8B58-EC3481F84A90_zps
Step 1: cut the Lock off of one end of a Ziptie and set it to the side. (In a place that it won't get lost) Discard the strip that you cut off.
2FE0C937-F9C2-4706-A343-0D684ECBE3A3_zps
Step 2: Get a new, undamaged Ziptie and route it through the eye of the washer.
73FF1DD4-36A6-474A-A88D-209F4C53607A_zps
Step 3: Rout the Ziptie with the washer upwards through the bottom of the mounting hole
6B951800-0786-4B01-B284-03D42835DE7A_zps
Step 4: Remember the Cut up Ziptie you sat aside earlier? slide it onto the end of the Ziptie currently stuck in the hole.
61F0AA59-93C2-47D7-B4CE-397FFC9D5826_zps
Step 5: Slide down until as snug as possible, and cut off excess.
5929CE5D-2B50-4CDB-A9B4-B84A5EBEFD02_zps
I dont know how many Datsuns have similar mounting grills, but it works on my B310. With slight modification it could be done on a '79 810 grille. Anyway, I hope this is helpful to someone!
  • Like 6
  • Replies 8
It works until you have to take your grill off. Then you gotta do it again but still nice, never thought of this before.  :thumbup:
this is true, and like thisismatt said, you can use a knife to undo it. but even if you just cut it off everytime, its SUPER cheap! And when your original clips get old and dry rotted, theyre even less useful than the zip ties....
True and True. I'm gonna do this cause with one little turn on my screws and they fall right out. Tried getting clips for them but keep getting the wrong ones so this is pretty cool.
Plus it keeps it "JDM"....................HAHA psych!
Ha! if anything though, it does keep it quirky and interesting. It's little things like that, that people notice at car shows.
