bluebird4200 Posted July 6, 2014 Report Share Posted July 6, 2014 I been pulling and disconnecting the wiring, bout to drain the radiator and slave cylinder. I only see 2 bolts under my 620 at the transmission. Aside of the connections in the engine bay, are those two bolts the only thing that needs to be disconnected at the rear end of the engine and transmission to remove them from the truck? Please help with experience. . Thanks! Quote Link to comment
ggzilla Posted July 6, 2014 Report Share Posted July 6, 2014 A lot needs to be disconnected from the transmission. Including driveshaft, speedometer cable, reverse light connector, top switch wiring, shifter, gearbox crossmember., etc. 1 Quote Link to comment
datsunaholic Posted July 6, 2014 Report Share Posted July 6, 2014 Don't NEED to disconnect the driveshaft- it'll fall out on it's own. Have something soft and disposable for it to fall on, though. Or put a bungee across under the front half to keep it from falling. Oh, and those 2 bolts? Heck of a lot easier if you take out all 6- the 2 at the trans mount, and the 2 on each side of the crossmember. Then remove the crossmember. You'll have to tilt the engine quite a bit to get it out, so hopefully you drained the transmission first. Makes a mess otherwise.. Quote Link to comment
bluebird4200 Posted July 6, 2014 Author Report Share Posted July 6, 2014 Okay, I will check them off as I go in the morning. Thanks for your help! Quote Link to comment
datzenmike Posted July 6, 2014 Report Share Posted July 6, 2014 Instead of draining the master, just unbolt the slave from the transmission and tie out of the way on the torsion bar. Be sure to secure the pushrod so that the weight of hydraulic fluid in the line above does not push the slave piston out. Saves removing lines and bleeding it later. Quote Link to comment
hvyd Posted July 8, 2014 Report Share Posted July 8, 2014 Pull them separately. Imo it makes it easier. Quote Link to comment
