teagueauto21 Posted June 10, 2014 Report Share Posted June 10, 2014 Im fixing to reindex my torsion bars and was wondering if anyone new how to adjust the camber on my truck never had a truck with a king pin front end. 1 Quote Link to comment
datzenmike Posted June 11, 2014 Report Share Posted June 11, 2014 Within reason a small drop won't change it much and toe in is a bigger more dangerous problem, and the easiest to adjust. Camber can be adjusted by adding or removing shims between the upper link spindle and the frame it's bolted to. It's not much and is intended for a stock ride height tweak. You can add as many shims as you want to move the top of the wheel inward but removing shims will only move the top of the wheel out a small amount before the spindle is flat against the frame 1 Quote Link to comment
teagueauto21 Posted June 11, 2014 Author Report Share Posted June 11, 2014 Thanks mike ! Im planning on dropping it about 4 in the front and 3 in the rear should i be concerned with lowering shocks in the rear i know you can use pinto shocks for the front any suggestions for rear 1 Quote Link to comment
ggzilla Posted June 11, 2014 Report Share Posted June 11, 2014 4" is not a small amount. 3 Quote Link to comment
teagueauto21 Posted June 11, 2014 Author Report Share Posted June 11, 2014 Yeah i know i want it low as possible without bags its my daily 1 Quote Link to comment
ggzilla Posted June 11, 2014 Report Share Posted June 11, 2014 The factory camber adjustment provision is not much and is intended for a stock ride height tweak. The good news is that you get the coveted negative camber. So no worries. Adjust the toe-in to spec and she'll handle right 1 Quote Link to comment
teagueauto21 Posted June 11, 2014 Author Report Share Posted June 11, 2014 Im more worried about tire wear will that be a big issue i know it was on my 01 frontier but i never re aligned the front end on it so is this gonna be a big issue 1 Quote Link to comment
ryknot Posted June 11, 2014 Report Share Posted June 11, 2014 I lowered mine and put new wheels and tires on it at the same time. I got the front alligned immediately after lowering it and my tires have worn nice and even. I also rotate my tires bout every 3k miles, Im willing to bet your truck probably hasnt had an allignment in many years, itll love it! 1 Quote Link to comment
datzenmike Posted June 11, 2014 Report Share Posted June 11, 2014 Thanks mike ! Im planning on dropping it about 4 in the front and 3 in the rear should i be concerned with lowering shocks in the rear i know you can use pinto shocks for the front any suggestions for rear The use of lowering blocks does not affect the shock length in the back. Take a look at it and just imagine the axle being moved higher by a spacer between it and the spring below it. The body/spring/shock stays the same. 1 Quote Link to comment
teagueauto21 Posted June 11, 2014 Author Report Share Posted June 11, 2014 I thought about that after i replied. Lol kinda had a brain fart 1 Quote Link to comment
]2eDeYe Posted June 11, 2014 Report Share Posted June 11, 2014 When lowering 4" you can remove the spacers between the a-arms and the frame mount. My truck was with .2 deg of stock camber last time I got the alignment checked. 1 Quote Link to comment
