SkeeterScooter Posted May 27, 2014 Report Share Posted May 27, 2014 I have a 78 620Went to add some oil today and noticed excessive air blowingout of the valve cover..- Is there anything that is commonly found among 620s that havethis issue?I know it's most likely bad rings, but I wanted to check. Quote Link to comment
wayno Posted May 27, 2014 Report Share Posted May 27, 2014 There is always blow-by at an idle, just don't add oil while it is running. My brand new LZ23 block had blow-by, but when I put my hand over the hole and revved it, it sucked on my hand. It all really depends on if you have leaks everywhere because of excessive blow-by blowing out the gaskets. Quote Link to comment
banzai510(hainz) Posted May 27, 2014 Report Share Posted May 27, 2014 crank case the block will blow air out when reved it will suck in. use a PCV valve at the intake. valve cover always blows air out at idle. I just route a hose down buy the trans or is stock use the pipeing to the aircleaner or if weber use a hose from aircleaner to a L shape tube to under the weber to suck the stink. Quote Link to comment
ggzilla Posted May 27, 2014 Report Share Posted May 27, 2014 The only thing that cause air to blow out the engine is the rings. A little clear flow is normal and is handled by the pcv system. Visible flow means the rings are not sealing well. Quote Link to comment
SkeeterScooter Posted May 29, 2014 Author Report Share Posted May 29, 2014 Thanks for the heads up guys, I guess I just sorta jumped the gun. I went through that nightmare with my last truck which is why I sold it. so I got really nervious when I thought it was happening again. IMMANOOB Quote Link to comment
