rodknee Posted May 21, 2014 Report Share Posted May 21, 2014 Just picked this up 7 it has no working headlights. Markers, hazzards, turn signals all work great. I just have no headlights, low or high beam. Swith?? Or are they just all bad. I am going to try & get a different light to check that but that seems strange, Any ideas????? Quote Link to comment
bonvo Posted May 21, 2014 Report Share Posted May 21, 2014 sounds like old headlights to me try disconnecting and reconnecting the plugs at the back of the bulbs first before you just replace the bulbs Quote Link to comment
banzai510(hainz) Posted May 21, 2014 Report Share Posted May 21, 2014 got a volt meter? start there. ck the fuses. Quote Link to comment
datzenmike Posted May 21, 2014 Report Share Posted May 21, 2014 Turn headlamps on and place a quarter across the top right hand side fuse. If they come on the fuse is bad. Then unplug fuse box and remove both mounting screws. Note the fuse size and location and throw them away. Soak fuse box in a bath of vinegar to remove corrosion overnight. Rinse and dry, replace fuses with NEW ones. DON'T use old fuses, they can't be trusted. NEW ONES!!!!! Install fuse box and be trouble free for years. Quote Link to comment
