rick9two Posted May 19, 2014 Report Share Posted May 19, 2014 I'm having problems registering my 620 again at the dmv due to turning the title into a salvage. I went in for a vehicle inspection and the clerk notices the vin stamp on the left inner fender screwed on. He sent me to the chip office to get a blue rivet stamp on it with a new vin. Can you guys help me out and send me pictures on how your stamp is being held up? I have seen other 620s with screws, am I correct or am I seeing things ? Guys, please help me out Quote Link to comment
ggzilla Posted May 19, 2014 Report Share Posted May 19, 2014 They used screws from the factory, at least the early ones. Quote Link to comment
ggzilla Posted May 19, 2014 Report Share Posted May 19, 2014 If the number on the plate doesn't match the number on the frame or the body number differs, they will need to verify your papers. Quote Link to comment
rick9two Posted May 19, 2014 Author Report Share Posted May 19, 2014 If the number on the plate doesn't match the number on the frame or the body number differs, they will need to verify your papers. I told him eveything matched then he brought a booklet that stated it needed to be on the firewall not the fender...so I wanna show them with pictures that's where it goes and with screws Quote Link to comment
nismo dr Posted May 19, 2014 Report Share Posted May 19, 2014 firewall is where it goes on 521 Quote Link to comment
datsunaholic Posted May 19, 2014 Report Share Posted May 19, 2014 620 it's screwed to the inner fender, but there's one riveted to the driver's doorframe and a VIN etched into the frame rail under the battery (just behind it, actually). There's nothing except the emissions sticker (through 74) on the firewall on a 620. The one on the frame is the only one that truly matters. The inspector is wrong, but good luck telling him that. Maybe he looked at where the VIN is on a 610. The factory manual shows the plate screwed on. Quote Link to comment
rick9two Posted May 19, 2014 Author Report Share Posted May 19, 2014 620 it's screwed to the inner fender, but there's one riveted to the driver's doorframe and a VIN etched into the frame rail under the battery (just behind it, actually). There's nothing except the emissions sticker (through 74) on the firewall on a 620. The one on the frame is the only one that truly matters. The inspector is wrong, but good luck telling him that. Maybe he looked at where the VIN is on a 610. The factory manual shows the plate screwed on. I did try telling him that, and I had no luck. Hopefully i get someone that is resonable and will bother listen and hear what I have to say. Where is the one on the frame ? Quote Link to comment
ggzilla Posted May 19, 2014 Report Share Posted May 19, 2014 Its on the frame. What I would do is bring along the Factory Service Manual and show him the photo. Otherwise you are just talking. Quote Link to comment
datsunaholic Posted May 20, 2014 Report Share Posted May 20, 2014 On the frame rail, not too far behind the bumper bracket mounts, but hard to see with the battery in place. Top of the frame rail. It's engraved in, not a plate. May need to sand the rust off to see it. Quote Link to comment
thatguy Posted May 20, 2014 Report Share Posted May 20, 2014 Make an appointment at your local chp office. It's no big deal. Just time. The chp will verify it a lot faster than the DMV will. 1 Quote Link to comment
MikeRL411 Posted May 20, 2014 Report Share Posted May 20, 2014 I did try telling him that, and I had no luck. Hopefully i get someone that is resonable and will bother listen and hear what I have to say. Where is the one on the frame ? See post number six for the answer. Quote Link to comment
