Lobo Posted May 13, 2014 Report Share Posted May 13, 2014 So I have a u67 head sitting here I under stand the head would be no good on my L16 so my question is. Is it worth putting the L20 cam on my w58 head and what is all involved in that is it just pull out the old and put in the new one or is there other things I have to replace I was reading that the L20 cam is a little upgrade Quote Link to comment
dr.feltersnatch Posted May 13, 2014 Report Share Posted May 13, 2014 Are there any stampings on the back of either cam? Are they both stock cams? Quote Link to comment
Lobo Posted May 13, 2014 Author Report Share Posted May 13, 2014 Ya stock cams the cam in the u67 is a u20 cam not sure on the w58 head Quote Link to comment
banzai510(hainz) Posted May 13, 2014 Report Share Posted May 13, 2014 I have a U67 on my L16. lowers the compression. and maybe more prone to pinging. but will get the car/truck running. Just bolt the MOFO on and call it good w58 is round port exhaust but pretty much the same Quote Link to comment
heretic Posted May 13, 2014 Report Share Posted May 13, 2014 you can swap cams no problem just double check that there is no binding with it & the cam towers. So I have a u67 head sitting here I under stand the head would be no good on my L16 so my question is. Is it worth putting the L20 cam on my w58 head and what is all involved in that is it just pull out the old and put in the new one or is there other things I have to replace I was reading that the L20 cam is a little upgrade Quote Link to comment
ggzilla Posted May 13, 2014 Report Share Posted May 13, 2014 Is it an L20B cam? That's the same as the L16 SSS cam. So if you don't rev the L16 to 7000 rpm, don't bother. Quote Link to comment
heretic Posted May 13, 2014 Report Share Posted May 13, 2014 BTW a W58 is an L20b head also did you mean W53.? ...... Is it worth putting the L20 cam on my w58 head ..... Quote Link to comment
datsunaholic Posted May 13, 2014 Report Share Posted May 13, 2014 The stock cams for a U67 head and a W58 head are identical. They're both L20B heads. 1 Quote Link to comment
Lobo Posted May 13, 2014 Author Report Share Posted May 13, 2014 Pretty sure it says w58 I will have to look better tonight when I get home Quote Link to comment
