sebpv Posted April 27, 2014 Report Share Posted April 27, 2014 So I broke the rear main bearing cap bolt when I tightened it down...The responsible are the side seals on the rear main cap. They bunched underneath as I tightened. Anyway, I cant find a reference for the size or a store to buy them. Can someone give me some hints? I appreciate the help. Quote Link to comment
ggzilla Posted April 27, 2014 Report Share Posted April 27, 2014 They are special bolts. Buy from Nissan Buy at junkyard Buy from ARP Quote Link to comment
sebpv Posted April 27, 2014 Author Report Share Posted April 27, 2014 would you by any chance know the description of the bolt i.e. thread type length and stuff..? as well im looking at replacing the head bolts. thx for your help Quote Link to comment
dr.feltersnatch Posted May 3, 2014 Report Share Posted May 3, 2014 go with arp. they are expensive but way stronger and they are way too important to just get one at the hardware store. and be sure to use a torque wrench. you dont want these to fail. http://www.northernautoparts.com/ProductDetail.cfm?ProductId=3543 Quote Link to comment
datzenmike Posted May 3, 2014 Report Share Posted May 3, 2014 Take one of the other bolts with you to the store. Next time install side seal in cap first, then install. Be sure to use dabs of sealer in the corner joints and moisten seal with oil. 1 Quote Link to comment
