windowless66 Posted March 31, 2014 Report Posted March 31, 2014 Hi guys, Having a bit of an issue with the aftermarket tachometer in the 620. I've got it all wired up but when the pulse wire is connected to the negative side of the coil the engine won't fire or if connected when running dies. I've hooked up tachos this way to other vehicles and they've worked fine is something different about the wiring with the 620. Thanks in advance Quote
bonvo Posted March 31, 2014 Report Posted March 31, 2014 my guess from half way around the world would be that your somehow grounding the coil Quote
windowless66 Posted March 31, 2014 Author Report Posted March 31, 2014 my guess from half way around the world would be that your somehow grounding the coil Your guess was right....Stupid mistake the guage bracket was grounding the coil to acc as soon as I got the torch under the dash it was a facepalm moment. Works fine now So glad you weren't right ggzilla! You gave me more credit than I was due :P I didn't even try to think logically after the cig fuse took out my headlights. Thanks again Quote
Lee R Posted March 31, 2014 Report Posted March 31, 2014 For years I had no clue what "torch" meant on the other side of the world....still cracks me up. 1 Quote
