85 Nissan 720 Posted February 3, 2023 Report Share Posted February 3, 2023 On 9/12/2018 at 1:54 PM, opie931246 said: Thanks for info! I figured the fuel system would need to be changed. Going to run single exhaust. The starter and oil pan should clear from what I can tell. From what I've read on other sites I can still use my 5speed trans with this swap. And will look into the engine mounts. I'm assuming I'll have to wire in the computer too and run electric fans/ water pump due to size restrictions. Any other tips would be awesome thanks. 2 minutes ago, datzenmike said: Also isn't the 4.3 pig heavy and a gas guzzler? Not really they are not bad on gas 17 to 21 mpg Quote Link to comment
85 Nissan 720 Posted February 3, 2023 Report Share Posted February 3, 2023 On 9/12/2018 at 1:54 PM, opie931246 said: Thanks for info! I figured the fuel system would need to be changed. Going to run single exhaust. The starter and oil pan should clear from what I can tell. From what I've read on other sites I can still use my 5speed trans with this swap. And will look into the engine mounts. I'm assuming I'll have to wire in the computer too and run electric fans/ water pump due to size restrictions. Any other tips would be awesome thanks. What computer you not going carburetor Quote Link to comment
datzenmike Posted February 3, 2023 Report Share Posted February 3, 2023 On 9/12/2018 at 10:54 AM, opie931246 said: Thanks for info! I figured the fuel system would need to be changed. Going to run single exhaust. The starter and oil pan should clear from what I can tell. From what I've read on other sites I can still use my 5speed trans with this swap. And will look into the engine mounts. I'm assuming I'll have to wire in the computer too and run electric fans/ water pump due to size restrictions. Any other tips would be awesome thanks. Who ever told you that was hitting the bong pretty hard. Chev 4.3 V6 and Nissan Z24 transmission two totally different engines and car makers. Nowhere in this 11 dimension string theory infinite universe is there a time line where those will totally bolt up. (note the sarcasm font) Quote Link to comment
Stoffregen Motorsports Posted February 3, 2023 Report Share Posted February 3, 2023 There are Chevy to Nissan transmission adapters, but I can't find any for the older 5 spd. I did find them for Z32 transmissions. Quote Link to comment
