BlackBird620 Posted March 12, 2014 Report Share Posted March 12, 2014 ALOT ! xD converting to dollars I spent about $4600 Nope still didnt get it on a dyno, cause the engine is very moody.. sometimes it drives amazing and sometimes it just keeps misfiring/fuel cutting, so I'm saving up for an ecu for now and yeah hopefully in 2 weeks time i'd be able to get an air intake, and im thinking of upgrading the suspensions(in 4-ish months time) and complete the gauge build remove all the stock gauges and replace with aftermarket ones hopefully after all that would be done i'll just have to make it look sexy :P :D Sounds like my Mazda had that problem with boost got the coldest plugs and replaced me wires and boots now runs amazing at any boost the under the overboost kill switch setting which is stuck at 15psi damn factory tune Quote Link to comment
Atomic Posted March 12, 2014 Report Share Posted March 12, 2014 And if you have ECU in your car, i suggest you to get OBD scanner: http://www.ebay.com/itm/MS509-OBDII-OBD2-Car-Vehicle-Engine-Fault-Diagnostic-Scanner-Code-Reader-Tool-/131064277530?pt=Motors_Automotive_Tools&hash=item1e840a2a1a&vxp=mtr Helps out a lot with modern engines. You just need to know the motor manufacture and the scanner will scan for codes Quote Link to comment
Spoona_Jay21 Posted March 12, 2014 Report Share Posted March 12, 2014 Holy Hell... a 2j'd S130.. THATS FLIPPIN AWESOME!!!!!!!! great work bro! Quote Link to comment
the_lettuce Posted March 13, 2014 Author Report Share Posted March 13, 2014 Could be blocked fuel lines/injectors. Or some sensor could be damaged (lamda or tps or crank position sensor etc...) What ECU are you going to get? I checked my injectors and they were in good conditions, i'll double check my fuel lines, and sensors after I finish exams :D I dont really know, might go cheap and get a piggyback Unichip Q, since its the cheapest one I can afford now, I was seeing the AEM v2, but No one where i'm from can program it, their expert with haltech,motec and the unichip. Quote Link to comment
the_lettuce Posted March 13, 2014 Author Report Share Posted March 13, 2014 Sounds like my Mazda had that problem with boost got the coldest plugs and replaced me wires and boots now runs amazing at any boost the under the overboost kill switch setting which is stuck at 15psi damn factory tune hahaha, I replaced all my wiring, so now it sometimes drives well and sometimes pms's -.- Quote Link to comment
the_lettuce Posted March 13, 2014 Author Report Share Posted March 13, 2014 And if you have ECU in your car, i suggest you to get OBD scanner: http://www.ebay.com/itm/MS509-OBDII-OBD2-Car-Vehicle-Engine-Fault-Diagnostic-Scanner-Code-Reader-Tool-/131064277530?pt=Motors_Automotive_Tools&hash=item1e840a2a1a&vxp=mtr Helps out a lot with modern engines. You just need to know the motor manufacture and the scanner will scan for codes Thank you, I'll check it out :D Quote Link to comment
the_lettuce Posted March 13, 2014 Author Report Share Posted March 13, 2014 Holy Hell... a 2j'd S130.. THATS FLIPPIN AWESOME!!!!!!!! great work bro! Thanks man :D Quote Link to comment
the_lettuce Posted March 13, 2014 Author Report Share Posted March 13, 2014 well.. one more update on the car.. I kinda got annoyed with the scrapping a lot in fact, and went to a proper exhaust shop the car is at the shop today, and these are the old exhausts on the car.. I didn't know the previous owner was heartless.. :) so as soon as the car finishes i'll post the new custom exhaust :D Quote Link to comment
the_lettuce Posted March 13, 2014 Author Report Share Posted March 13, 2014 Just finished installing the exhausts, took it for a drive it to see if there was a difference or not, at first the car was at 0.5 bar ( I think thats roughly 7 psi ) so when the exhausts got in, the boost rose to 0.6bar on its own, but was still fuel cutting, tampered with the boost and fuel regulator, and decided to open it to 0.7 bar (10-ish psi) works perfectly :D <3 here's a short video : View My Video P.s: Please dont comment on my crappy driving xD this is my first stick car, and still learning to drive it properly :rofl: 1 Quote Link to comment
Atomic Posted March 14, 2014 Report Share Posted March 14, 2014 Just finished installing the exhausts, took it for a drive it to see if there was a difference or not, at first the car was at 0.5 bar ( I think thats roughly 7 psi ) so when the exhausts got in, the boost rose to 0.6bar on its own, but was still fuel cutting, tampered with the boost and fuel regulator, and decided to open it to 0.7 bar (10-ish psi) works perfectly :D <3 here's a short video : View My Video P.s: Please dont comment on my crappy driving xD this is my first stick car, and still learning to drive it properly :rofl: Sweet sounds, but please, buy BOV (blow off valve). The sound ''whrhrhrhrhrhrhr'' is due the air that's coming from turbo hits the shut throttle plate and makes its way back to turbo and forces it to spin backwards. Correctly set bov will save your turbo :) Quote Link to comment
the_lettuce Posted March 16, 2014 Author Report Share Posted March 16, 2014 Sweet sounds, but please, buy BOV (blow off valve). The sound ''whrhrhrhrhrhrhr'' is due the air that's coming from turbo hits the shut throttle plate and makes its way back to turbo and forces it to spin backwards. Correctly set bov will save your turbo :) Yeah, thats next on my list, but I dont really care much about the turbo since its a really cheap knockoff one so either way it will die in few months time. I kinda like the "whrhrhrhrhrhr" sound though :rofl: . Thanks for the advice :D Quote Link to comment
Atomic Posted March 16, 2014 Report Share Posted March 16, 2014 Yeah, thats next on my list, but I dont really care much about the turbo since its a really cheap knockoff one so either way it will die in few months time. I kinda like the "whrhrhrhrhrhr" sound though :rofl: . Thanks for the advice :D And the BOV will help to reduce ''turbo lag'' :) And here is some sweet BOV sounds: ''pshhhhh'' And are you planning to change your turbocharger then? Quote Link to comment
the_lettuce Posted March 16, 2014 Author Report Share Posted March 16, 2014 And the BOV will help to reduce ''turbo lag'' :) And here is some sweet BOV sounds: ''pshhhhh'' And are you planning to change your turbocharger then? WOW it sounds amazing and "fierce" ,, yeah hopefully i'll open up a "turbo" savings account in the bank sometime this week so I dont touch it till I can afford a proper turbo. But now I have a problem, my fuel tank, prior to the 2jz swap, always felt pressured, like I drive it for a few miles and just park it turn it off, open the fuel tank , soo much pressure leaves, after the 2jz swap, I got the bosch inline fuel pump (hoping it would fix the problem but it didnt) the tank still has soo much pressure everytime I open it.. is that normal ? Quote Link to comment
Atomic Posted March 16, 2014 Report Share Posted March 16, 2014 WOW it sounds amazing and "fierce" ,, yeah hopefully i'll open up a "turbo" savings account in the bank sometime this week so I dont touch it till I can afford a proper turbo. But now I have a problem, my fuel tank, prior to the 2jz swap, always felt pressured, like I drive it for a few miles and just park it turn it off, open the fuel tank , soo much pressure leaves, after the 2jz swap, I got the bosch inline fuel pump (hoping it would fix the problem but it didnt) the tank still has soo much pressure everytime I open it.. is that normal ? Fuel pressure drops? What readings do you get? Quote Link to comment
the_lettuce Posted March 16, 2014 Author Report Share Posted March 16, 2014 Fuel pressure drops? What readings do you get? Nope everything is normal.. but the tank itself releases pressure when I open it, fill the tank with gas.. it's kinda worrying me Quote Link to comment
Atomic Posted March 16, 2014 Report Share Posted March 16, 2014 Nope everything is normal.. but the tank itself releases pressure when I open it, fill the tank with gas.. it's kinda worrying me It's normal and it happens a lot in a hot climate as the gasoline starts to vapor Quote Link to comment
Atomic Posted March 16, 2014 Report Share Posted March 16, 2014 And if you're interested, here is some reading: http://www.mediafire.com/download/x9cu2659042w750/Maximum+Boost+-+Corky+Bell.pdf I have used that book as a guide through my build for a turbocharging a 1,5liter A15 engine and there are some informative formulas for sizing turbochargers etc~ Quote Link to comment
the_lettuce Posted March 17, 2014 Author Report Share Posted March 17, 2014 It's normal and it happens a lot in a hot climate as the gasoline starts to vapor Ohh didnt think about it like that.. And if you're interested, here is some reading: http://www.mediafire.com/download/x9cu2659042w750/Maximum+Boost+-+Corky+Bell.pdf I have used that book as a guide through my build for a turbocharging a 1,5liter A15 engine and there are some informative formulas for sizing turbochargers etc~ Thank you, I'll read it :D Quote Link to comment
the_lettuce Posted March 29, 2014 Author Report Share Posted March 29, 2014 Hello , Lettuce is back again .. So few days ago I decided to take the car for a drift.. anyways nothing major happened just casual drifting :rofl: two days after that I was driving on the highway at 50 miles per hour i heard a "CLUNK" I inspected the car and nothing was visible I thought I was just hearing noises again.. but I did drive it to my friends garage since I was worried .. and as soon as I reached the battery just randomly fell on the turbo manifold :confused: even though it was tightened and secured .. suddenly the crank pulley just fell on its own :crying: went to the dealership they said they dont have any supra parts for the past 15 years .. i said lexus IS300 or GS300 (2002-03 models) they said no.. so I went to the scrap yard and found one which looked brand-ish new ? :huh: anyways so we tried getting an airgun but the radiator didnt give us any space.. we used the crank-wrench method didnt work .. so we took of the radiator YAY now we have space :w00t: well I found out the radiator was rusted as hell from the inside :) .. but thats gonna be worked on later so it took us about 3 hours to pull the crank pulley bolt off (since we didnt have experience and professionals were charging a lot ..) anyways we decided to try the heat method even though i was scared cause I just thought it would harm the engine from the inside but it did work and we managed to get the bolt out and we were really tired and knew we needed special tools to remove the crank pulley so hopefully today or tomorrow we would work on it. just wanted to update you guys on what happened :D Quote Link to comment
BlackBird620 Posted March 29, 2014 Report Share Posted March 29, 2014 Most mechanics in the states will check which direction the engine turns and put a socket on a breaker bar propped against the frame and use the starter to break it loose Quote Link to comment
the_lettuce Posted April 2, 2014 Author Report Share Posted April 2, 2014 Most mechanics in the states will check which direction the engine turns and put a socket on a breaker bar propped against the frame and use the starter to break it loose Yeah thats what we did but with no luck till we heated the bolt for a bit and it unscrewed easily Quote Link to comment
the_lettuce Posted April 2, 2014 Author Report Share Posted April 2, 2014 anyways so after the bolt was out it was a pita to get the pulley out .. I searched everywhere for the crank puller device as i saw people use it in forums/videos etc.. but the shops were selling them for $500-$700 (it doesnt really make sense selling these for a huge amount of money and the standard crank puller was no where to be found ..) anyways I passed down to a little garage I asked if I could borrow a puller if he had one available, he gave it to me and but it didnt do anything -.- i was too tired to go on so the next day I did it again using some spontaneous methods as I was learning on my own but with no luck finally gave up and came back the next day and I used a hammer :D and it worked :O and thats how my crank pulley looked like after being hammered xD My rusted radiator is in another shop getting re-fabbed and cleaned so I'll install it tomorrow and get the car running again. 1 Quote Link to comment
