zed Posted September 2, 2008 Report Share Posted September 2, 2008 Another newbie question - I've searched "cam sprocket", and read all the posts, but they don't seem to apply to my engine. (Sadly, Hainz vid is too big to download on dialup:() So, please can someone explain why the bright/silver timing chain link is next to the "3" on the sprocket? My manual says it should be on "1". It's a standard L18 engine, which has never been worked on... done about 250k miles, so the timing chain should be stretched right? I'm collecting parts and information for a rebuild here... many thanks guys Quote Link to comment
datsunaholic Posted September 2, 2008 Report Share Posted September 2, 2008 The bright link is on "3" but where is the other bright link? If it's lined up with the mark on the sprocket AND the cam sprocket pin is in #3 then someone set it there. If the engine has been run the bright link will land anywhere- it won't hit the number every revolution. When I did the head on my L20B the bright link was nowhere to be found, BUT someone had set the static timing on #1. No wonder it backfired all the time. Quote Link to comment
bonvo Posted September 3, 2008 Report Share Posted September 3, 2008 i never understood this there are 3 cam timing locations? Quote Link to comment
banzai510(hainz) Posted September 3, 2008 Report Share Posted September 3, 2008 yes there is 3 its on my vid,http://www.guba.com/general/search?query=hainz&set=5&x=0&y=0 it advances the chain for chain stretch or cam advance L20s came from factory set in #2 position for emmissions Quote Link to comment
bonvo Posted September 3, 2008 Report Share Posted September 3, 2008 got it so ill have to watch the video :P Quote Link to comment
datsunaholic Posted September 3, 2008 Report Share Posted September 3, 2008 L20B wasn't set at #2 for emissions, it's because the chain is longer and has more static "endplay" due to having more links. Quote Link to comment
banzai510(hainz) Posted September 3, 2008 Report Share Posted September 3, 2008 Doug you sure???? 2 links longer is going to need 4 deg advance just for that porpose? Doesnt really matter. if you got it set on 1 2 or 3 and its a new chain it will run!!!! if a Performance cam then one needs to dial it in with a degree wheel.( I dont know how to do that). General rule of thumb is if cam is advance the power comes on sooner Quote Link to comment
datsunaholic Posted September 3, 2008 Report Share Posted September 3, 2008 I've built both L20Bs and L16s and the cam timing on an L16 at #1 is not the same timing as #1 on an L20B... combination of longer chain and the increased distance from sprocket to sprocket. Of course each engine varies... a milled head causes cam lag, all else equal. It's amazing what just a few thousandths does. I do know what happens when you set an otherwise stock L20B on #1... a bit of backfiring out the intake when trying to start it, at least cold. Same effect as a worn chain, the cam ends up lagging the crank and dist timing. When it heats up the block/head grows more than the chain so it tightens back up a little bit. Quote Link to comment
zed Posted September 9, 2008 Author Report Share Posted September 9, 2008 thanks everyone for the info Quote Link to comment
