mcordero8 Posted February 2, 2014 Report Share Posted February 2, 2014 Does anyone know if wheels with this criteria will fit my 620 pickup? P.C.D = 6 X 139.7 - Size = 12mm X 1.25 Quote Link to comment
kelowg Posted February 2, 2014 Report Share Posted February 2, 2014 those specs, yes but center hole opening and offset r the most important. lots of other things come into play. try googling 620 wheels/ratsun https://www.google.com/search?q=620+wheels/ratsun&rlz=1C1CHFX_enUS485US485&espv=210&es_sm=93&source=lnms&tbm=isch&sa=X&ei=TYTuUqS4O43qoASi4oH4Bw&ved=0CAoQ_AUoAg&biw=1440&bih=767 Quote Link to comment
ggzilla Posted February 2, 2014 Report Share Posted February 2, 2014 The need to have s pcd of 6 x 5.5" Quote Link to comment
kelowg Posted February 2, 2014 Report Share Posted February 2, 2014 6x5.5,thats the same thing as 6x139.7 Quote Link to comment
ggzilla Posted February 2, 2014 Report Share Posted February 2, 2014 The specification is 5.5". If you convert 5.5" into metric it is approximately 139.7 mm. Quote Link to comment
KlassicMotion Posted February 2, 2014 Report Share Posted February 2, 2014 Edit your profile so we can see what year 620 you have. Maybe you already have this covered, but: As far as offset goes, the early trucks are different. I learned that the hard way. When I asked, everyone said I could run stock Chevy Steelies with no problems, but my '73 won't accept the same negative offset as the later trucks. I had to run spacers front and rear just to get my 16x6.5" Chevy steelies on. There is a benefit to running spacers though; you can run the smaller center bore. Quote Link to comment
kevins750 Posted February 2, 2014 Report Share Posted February 2, 2014 this is a list I use..scroll down a bit for the list... http://www.roadkillcustoms.com/hot-rods-rat-rods/Wheel-Bolt-Pattern-Cross-Reference-Database.asp?Makes=Ford&Models=COURIER+PICKUP#axzz2rexklLdP 1 Quote Link to comment
orangie Posted February 2, 2014 Report Share Posted February 2, 2014 Some other things to consider, the center bore and offset/backspacing. In all honesty, I don't know what the centerbore is because I'm running early 720 hubs. I believe you can have the hubs machined down to make it fit, but a spacer is cheaper. Something else to consider is the width of the wheel. Manual steering and wide tires is a chore in the parking lot. Quote Link to comment
Aibast Posted February 7, 2014 Report Share Posted February 7, 2014 I'm running my trucks on Nissan Pickup (720) original steel rims. Don't know the offset on these. Fits well with 205/65/R15 tyres. Quote Link to comment
mcordero8 Posted February 7, 2014 Author Report Share Posted February 7, 2014 Cool looking truck. Quote Link to comment
mcordero8 Posted February 11, 2014 Author Report Share Posted February 11, 2014 I got my rims, they are 15 x 7.5" wide does anyone know if 225/60/R15 will fit on this rim? Quote Link to comment
KlassicMotion Posted February 11, 2014 Report Share Posted February 11, 2014 To answer your question, yes it will fit. That tire size is rated to be mounted on 6-8" rims. I will let you do the research. Go to TireRack, click tires, search for your size, click on a tire, click on "specs" (in blue under the pic of the tire), and that will tell you some dimension specs. Everything I'm seeing mounts that tire on 6.5" rims, so the dimensions are different than what you're planning to do. Hopefully someone will be able to respond and show you a pic of that tire/wheel combo. Quote Link to comment
