braveops Posted January 23, 2014 Report Share Posted January 23, 2014 i cant seem to find what mounts guys are using? i thought some where using a gm tranny mount? i have both old mounts from l16 and ka ones but the dont look to tough. what others are guys using? Quote Link to comment
sssr20det510 Posted January 23, 2014 Report Share Posted January 23, 2014 http://www.ebay.com/itm/like/291054340661?lpid=82 Quote Link to comment
braveops Posted January 23, 2014 Author Report Share Posted January 23, 2014 do i have to mod it to fit or will it bolt up to tranny??? thanx for link Quote Link to comment
sssr20det510 Posted January 23, 2014 Report Share Posted January 23, 2014 What tranny crossmember are you using Quote Link to comment
braveops Posted January 23, 2014 Author Report Share Posted January 23, 2014 most likely one i make for it as i think the stock ones would have to hacked up to much to use Quote Link to comment
sssr20det510 Posted January 23, 2014 Report Share Posted January 23, 2014 Experimental enginering sells one for the swap that mount will work with Quote Link to comment
braveops Posted January 23, 2014 Author Report Share Posted January 23, 2014 i went there but site seems to be down. i made front mounts so not sure if i buy one if it would work for me vg30.xxx is Under Construction! New Experimental Engineering website/store coming soon! Please check back. In the meantime you may email us at info@vg30.xxx Quote Link to comment
sssr20det510 Posted January 23, 2014 Report Share Posted January 23, 2014 You can make your own this is what theres look like http://www.the510realm.com/viewtopic.php?f=10&t=14181 Quote Link to comment
Docsis510 Posted January 23, 2014 Report Share Posted January 23, 2014 Try T3 just bought one from them and it worked great.. https://technotoytuning.com/nissan/510 Quote Link to comment
braveops Posted January 23, 2014 Author Report Share Posted January 23, 2014 thanx guys that t3 one dont look to bad of price Quote Link to comment
carterb Posted January 23, 2014 Report Share Posted January 23, 2014 Dave's (Experimental Engineering) stuff is still available while the site is down: best to buy through his ebay store http://stores.ebay.com/Mr-510s-Store --carter Quote Link to comment
q-tip Posted January 23, 2014 Report Share Posted January 23, 2014 ^^ agreed on Daves products, I'm running his teams mount in my ka'd 510, stuff is top notch!! Quote Link to comment
sssr20det510 Posted January 23, 2014 Report Share Posted January 23, 2014 T3 one looks like daves ???? Quote Link to comment
q-tip Posted January 24, 2014 Report Share Posted January 24, 2014 Its probably similar but I'm sure Dave's came first. Quote Link to comment
braveops Posted January 24, 2014 Author Report Share Posted January 24, 2014 it sucks that the rubber mount is just as much as the steel mount Quote Link to comment
