dustinbm Posted January 20, 2014 Report Share Posted January 20, 2014 I have a 75 620, the fan blows strong and heater was working until I changed a leaky heater control valve. I am sure the valve is open and both hoses connect to it get warm once the truck heats up. However the heater never blows any warm air. Thanks in advance Also, a big thanks to everyone in this community. This is such a great resources. Quote Link to comment
Eagle_Adam Posted January 20, 2014 Report Share Posted January 20, 2014 you should really post some pics and an intro before asking for help..... but welcome to Ratsun, now go replace your thermostat and clean your heater core if you haven't already and ill bet you get your heat back Quote Link to comment
dustinbm Posted January 20, 2014 Author Report Share Posted January 20, 2014 My apologies and thank you for your response. I will get some pics together and make an introduction post over the next week. In the mean time: The thermostat is brand new. I will clean the heater core but is there something else that could be going on since the heater worked great right before the valve change? Quote Link to comment
Eagle_Adam Posted January 20, 2014 Report Share Posted January 20, 2014 i doubt it, just cus the thermostat is new doesn't mean it works ;) pull it out and test it to make sure it opens at the right temp Quote Link to comment
Eagle_Adam Posted January 20, 2014 Report Share Posted January 20, 2014 even easier test, does your temp gauge work? Quote Link to comment
dustinbm Posted January 20, 2014 Author Report Share Posted January 20, 2014 The current thermostat was in before I changed the heater control valve and when heater worked. Also, yes the temp gauge works. Quote Link to comment
JNHEscher Posted January 20, 2014 Report Share Posted January 20, 2014 Perhaps the c-clip holding the plunger inside the control valve wasn't installed? Did you run the valve by hand and watch the plunger move before installing it? Just a thought that came to mind. Quote Link to comment
Eagle_Adam Posted January 20, 2014 Report Share Posted January 20, 2014 when you run you truck does it come up to temp properly according to the gauge? Quote Link to comment
BenJammin Posted January 23, 2014 Report Share Posted January 23, 2014 Are you sure you don't have the A/C on ? I kid....I kid. Had to take my chances with the only crowd that would even bother to possibly grin at that statement. 1 Quote Link to comment
Eagle_Adam Posted January 23, 2014 Report Share Posted January 23, 2014 not all of us are that spoiled Ben :P Quote Link to comment
datzenmike Posted January 24, 2014 Report Share Posted January 24, 2014 You are going to want to flush the core anyway so pull both hoses off the motor. The one on the side of the head and the other down by the lower rad hose. Use a garden hose and flush water through in both directions, several times. If the heater isn't working the valve may be closed, in which case you won't be able to flush water through but at least you will have found the problem. IOf you can flush water through then the hot water can circulate. Look at the other flap door linkages... air has to flow through the core to get hot. Quote Link to comment
thisismatt Posted January 24, 2014 Report Share Posted January 24, 2014 Are you sure you didn't connect the inlet and outlet hoses directly to both sides of the valve? :P Quote Link to comment
BenJammin Posted January 24, 2014 Report Share Posted January 24, 2014 Are you actually seeing the valve lever move when you go from hot to cold on the control panel, and does it move freely or with moderate resistance ? (i.e. the control cable may not be anchored properly or broken inside ). Pics of your install would be a big plus here. Quote Link to comment
