kevins750 Posted January 17, 2014 Report Share Posted January 17, 2014 So I have a Weber DFEV on my L20b...I read that this carb has the primary and secondary swapped, which means that my primary is farther from the motor than my secondary is...My intake does have an open plenum if that makes a difference...Should I turn the carb around? Quote Link to comment
laotsu Posted January 17, 2014 Report Share Posted January 17, 2014 I had the same carb on my l16, just flip it. Quote Link to comment
ggzilla Posted January 17, 2014 Report Share Posted January 17, 2014 It doesn't matter when the plenum is opened up. Run it either way. Quote Link to comment
banzai510(hainz) Posted January 17, 2014 Report Share Posted January 17, 2014 maybe hogg out the plunum so the bigger butter will fit over it Quote Link to comment
datzenmike Posted January 17, 2014 Report Share Posted January 17, 2014 As long as it fits the manifold, the throttle opens and closes and the throttle cable is well positioned run as it is. The motor won't know the difference so don't tell it. Quote Link to comment
