Eagle_Adam Posted January 5, 2014 Report Share Posted January 5, 2014 I'm working with Draynor to install and dial in the "LZ 21 long rod" that he and Laecaon put together and I'll be honest i haven't found a clear answer to a specific question I have so here goes! In an LZ what crank pulley "should" be used? The reason I have this question is because if I were to tune Derek's motor by ear the timing light tells me his motor is at where 25 would be on the timing plate...... And I'm wondering if the l20b crank pulleys timing mark is deceiving me and I should time it by ear or if I should believe what I see and sleep more than 15 hours in a week ? Quote Link to comment
Z-train Posted January 5, 2014 Report Share Posted January 5, 2014 I used the L-20B pulley as it matches the TC. 1 Quote Link to comment
Farmer Joe Posted January 5, 2014 Report Share Posted January 5, 2014 when the crank shows 0deg on the pulley and the mark, are you at TDC? thats the only way i could think to make sure it all "lined up", yanno? Quote Link to comment
EricJB Posted January 5, 2014 Report Share Posted January 5, 2014 Every Z22/Z24 I have seen had a 2 piece pulley/ harmonic balancer. I asked around when I was putting mine together and got different answers. My theory is, when they increased the stroke of the crank, it must have had some harmonic issues (think tuning fork). So they dumbed it down with a bolt on damper. Lack of it could lead to the flywheel coming loose, or even crank breakage. I went with the damper pulley. One thing you can do when assembling is use an indicator on the #1 piston to find TDC. Rotate the motor both directions so the dial reads .010 either direction, mark the pulley in both readings. Then move the timing marker to line up in the middle of the marks. Dead nuts. Once it is together you can buy a tool the threads into the spark plug hole. Rotate one direction untill the toll hits the piston, mark the pulley. Rotate in the other direction, mark the pulley. TDC is at the center of the two marks. Quote Link to comment
hang_510 Posted January 9, 2014 Report Share Posted January 9, 2014 match it to the crank. i have a L24 HB on mine, to clear the sway bar. L20b crank is balanced. Z22/Z24 crank is not. Quote Link to comment
Eagle_Adam Posted January 9, 2014 Author Report Share Posted January 9, 2014 the L20b crank is whats installed so its keeping the L20b pulley - thank you for the info Quote Link to comment
Eagle_Adam Posted January 9, 2014 Author Report Share Posted January 9, 2014 Every Z22/Z24 I have seen had a 2 piece pulley/ harmonic balancer. I asked around when I was putting mine together and got different answers. My theory is, when they increased the stroke of the crank, it must have had some harmonic issues (think tuning fork). So they dumbed it down with a bolt on damper. Lack of it could lead to the flywheel coming loose, or even crank breakage. I went with the damper pulley. One thing you can do when assembling is use an indicator on the #1 piston to find TDC. Rotate the motor both directions so the dial reads .010 either direction, mark the pulley in both readings. Then move the timing marker to line up in the middle of the marks. Dead nuts. Once it is together you can buy a tool the threads into the spark plug hole. Rotate one direction untill the toll hits the piston, mark the pulley. Rotate in the other direction, mark the pulley. TDC is at the center of the two marks. this is awesome BTW ^^ Quote Link to comment
hang_510 Posted January 11, 2014 Report Share Posted January 11, 2014 the L20b crank is whats installed so its keeping the L20b pulley - thank you for the info you may be able to find a single groove pulley if your just running an alt. Quote Link to comment
