City Hunter Posted August 23, 2008 Report Share Posted August 23, 2008 What do you guys prefer? Fastest without chemicals. Wire brush, sand paper? I'm abot to go stock up on materials for stipping the 240z down to metal and seeing how bad she really is. Right now I just have a crappy palm sander, some angle grinders, a block, but hopefully my friend will eb loaning me a electric orbital pretty soon. For now I gotta go with what I have. Air really isnt a option as it's a bit noisy for the apartments. I'm thinking maybe 80 or 200grit? Quote Link to comment
City Hunter Posted August 23, 2008 Author Report Share Posted August 23, 2008 I'm starting to think I should just go buy one of the milwauki 7/9inch electric sanders 5000 rpm. What do you guys think? Can I get one cheaper that works as good? http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100609406&N=10000003+501288+90401 Quote Link to comment
jesusno2 Posted August 23, 2008 Report Share Posted August 23, 2008 Aircraft paint stripper! Quote Link to comment
City Hunter Posted August 23, 2008 Author Report Share Posted August 23, 2008 yeah that would be nice, but I cant use it in my apartment garage :) Quote Link to comment
Bleach Posted August 23, 2008 Report Share Posted August 23, 2008 I used an orbital sander with 80 grit (the lowest I could find) and it worked pretty good. Find a source online and order them in 10 packs. If you can find 40 grit that will get through the paint faster. Finish it to bare metal with the 80 so its not so rough on the metal. On a truck I had, the roof had some heavy surface rust. I had a polisher that I 'made' some 40 grit discs for and it blew through that rust. I smoothed it out with 80 and 120 grit later. Quote Link to comment
City Hunter Posted August 24, 2008 Author Report Share Posted August 24, 2008 I ended up buying a craftsman 6inch polisher/sander for 80 bucks, and grabbed a 25 pack of 80grit adhesive discs for 9 bucks. Should last me through the night I hope :) I can get lower grit, I may go back and buy some 40 grit discs tomorrow. Hopefully I can get this baby stripped down by next weekend. I suppose I'll nbeed to go buy some metal etching spray can primer to cover it up for the time being. Quote Link to comment
hogboy52 Posted August 24, 2008 Report Share Posted August 24, 2008 .. Stop now! You don't even have an air compressor. Stripping to bare metal unless you are doing some local panel repair is usually a serious mistake. If there are multiple layeres of paint then you could sand down to the original base-color coat, and using long board and flexible sanders, smooth the surface beyond factory standards. If the base coat has held up all these years, it will hold up longer than your base metal trials. Quote Link to comment
420n620 Posted August 24, 2008 Report Share Posted August 24, 2008 if you got lots of layers of paint, 40 will work for you faster but if not stick with 80, make sure you dont stay in one area for to long because het heat will warp your panel, then you will end up with a "very friendly" vehicle, it will be waving at everyone.. :D Quote Link to comment
City Hunter Posted August 24, 2008 Author Report Share Posted August 24, 2008 too late,. I have to do some rust repairs so im taing the thing down to metal. Finding some bondo spots along the way. I have a air compressor, im not going to use it though. Loud ass annoying thing. This electric 6inch is doing pretty good, but it does clog quick, so im gonna drop down to 40 tomorrow then go over any areas that are too gauled with some 120. I suppose I can just strip down the areas that in need of rust repair and just smooth out the rest of the areas. Looks like the car was stripped and repainted at one time. But it's a black looking primer and orange over the top. Quote Link to comment
jesusno2 Posted August 24, 2008 Report Share Posted August 24, 2008 have fun filling those deep ass scratches better get some house of color kd2000 filler primer cause that is the only primer i know of that will fill those kinda scratches. or coat the whole rig in skim coat of bondo. Quote Link to comment
City Hunter Posted August 24, 2008 Author Report Share Posted August 24, 2008 your such a positive guy :) Quote Link to comment
jesusno2 Posted August 24, 2008 Report Share Posted August 24, 2008 I'm just saying if your gonna strip a car down to bare metal your going to have to go through some steps to do it right or all the time you spent will be wasted when it starts to rust again. your going to have to get a etching primer to go direct to metal most other primers will not seal bare metal kd 2000 hok primer can be direct to metal and a filler primer also. It like killing 2 birds with one stone kinda deal Quote Link to comment
City Hunter Posted August 24, 2008 Author Report Share Posted August 24, 2008 Yeah I know I would have to use a etching primer. I'll look into that kd stuff. Since the paint does seem to be pretty good, I think I will take your advice on not taking the tnire car down. I'm going to leave the rest alone right now and start working on the rusted spots, although my passenger rear quarter is definately going to have to come down as there is bondo flaking. Oh and those deep looking scratches are actually paint or the rubber off my sander. I checked today. Quote Link to comment
