DatDoug Posted August 23, 2008 Report Share Posted August 23, 2008 How easy to pull and replace? Where do you get new ones? This is for my 73 510. Quote Link to comment
Icehouse Posted August 23, 2008 Report Share Posted August 23, 2008 Franks house 10 bucks each. Quote Link to comment
DatDoug Posted August 24, 2008 Author Report Share Posted August 24, 2008 I'd probably be over there if I lived in Everett. Of course I'd probably be over there a lot if I lived there:D Quote Link to comment
banzai510(hainz) Posted August 27, 2008 Report Share Posted August 27, 2008 remove the half shaft. The wheel end is EZ but keep together as I use a BIG LONG screw driver as a holder to keep the axle from spinning then trying to loosen the nuts on the diff side. the diff side you need a thin wrench and try to get full movement w/o rounding the nuts. Sometimes better to get from the TOP side. I had a local NAPA(had a small shop behind) swap out the Ujoints which I supplied. GMB japan 15-22$ is a cheaper brand but the USA made units are VERY GOOD ,about 40$ per U joint. I have spare halfshafts and just swap out the whole shaft when a u joint goes bad. replace U joint when $ and time permits later Quote Link to comment
