olderdat620 Posted December 3, 2013 Report Share Posted December 3, 2013 I have had all my Datsun pickups lowered my son came back from the war and saw one of my part trucks and said that is his next fishing truck, so I want to lift the front end --- so my question is it is a 73 620 does anybody make a lift kit for it any help would be appriciated Quote Link to comment
thatguy Posted December 3, 2013 Report Share Posted December 3, 2013 Quick google search. Not your only option. http://www.truckspring.com/suspension-parts/helper-springs/air-spring-kits/air-lift-ride-control.aspx?make=NISSAN&year=1973&model=620+Pickup Thank your son for his service. Quote Link to comment
datzenmike Posted December 3, 2013 Report Share Posted December 3, 2013 Simply turn the torsion bars back up and raise the front. If you have lowering blocks in the back take them out. 2 Quote Link to comment
Eastcoast521 Posted December 7, 2013 Report Share Posted December 7, 2013 Back in the day they ised to make body lift blocks. As noted above you can also raise the front with the torsion bars and you could raise the back by putting the axle under the leaf springs. Quote Link to comment
]2eDeYe Posted December 9, 2013 Report Share Posted December 9, 2013 Cranking the torsions works pretty good, does limit the droop though. Quote Link to comment
