nickel&dime Posted October 30, 2013 Report Share Posted October 30, 2013 I found some diffentrials for sale. Which would fit my wagon. I'm a noob buy I think the R180 would fit cuz the solid rear right? * One R-160 open 3.7 ratio with Datsun 510 stub axles attached. * One R-180 open 3.9 ratio with Datsun 720 truck stub axles attached. These will bolt into most Datsuns, '68-'85 and will work in Subarus, as long as you remove the older stub axles. $150 for the R-160 and $200 for the R-180. Quote Link to comment
datzenmike Posted October 30, 2013 Report Share Posted October 30, 2013 R is for independent rear suspension IRS. That's a differential bolted solidly to the frame with two short driveshafts to each wheel. The 510 sedan has this. The 510 goon has a solid H-190 rear axle riding on springs. Nothing R- will work on your goon. 1 Quote Link to comment
nickel&dime Posted October 30, 2013 Author Report Share Posted October 30, 2013 R is for independent rear suspension IRS. That's a differential bolted solidly to the frame with two short driveshafts to each wheel. The 510 sedan has this. The 510 goon has a solid H-190 rear axle riding on springs. Nothing R- will work on your goon. Thanks for the quick reply how would I get lsd? Quote Link to comment
Tristin Posted October 30, 2013 Report Share Posted October 30, 2013 Thanks for the quick reply how would I get lsd? Custom modify another straight axle that came with LSD. Theres a few options out there. RX7 is one. 1 Quote Link to comment
nickel&dime Posted October 30, 2013 Author Report Share Posted October 30, 2013 Nm I found my answer Quote Link to comment
Fat510 Posted October 31, 2013 Report Share Posted October 31, 2013 R is for independent rear suspension IRS. That's a differential bolted solidly to the frame with two short driveshafts to each wheel. The 510 sedan has this. The 510 goon has a solid H-190 rear axle riding on springs. Nothing R- will work on your goon. does the A10 have the h190 as well? Quote Link to comment
datzenmike Posted October 31, 2013 Report Share Posted October 31, 2013 No it's an H-165 Quote Link to comment
Fat510 Posted November 1, 2013 Report Share Posted November 1, 2013 No it's an H-165 thanks :) Quote Link to comment
nkl dme Posted December 5, 2013 Report Share Posted December 5, 2013 So as a goon owner I'm familiar with the custom rear end options out there but has anyone here pushing 300bhp, lock-welded a h190 in a goon and had success for auto-x purposes? Or do the axels go out quickly with that kind of power? Quote Link to comment
datzenmike Posted December 5, 2013 Report Share Posted December 5, 2013 A Lincoln Locker is best for going in a straight line. Auto-X is all turns and curves and will bring out all the worst in a welded diff. For one, a locked differential will induce under steer. Haven't heard of axle splines going bad on an H-190 but maybe this is just that the tires are not large enough and the vehicle heavy enough. The tire acts like a fuse by losing traction well before the torque can twist anything. Quote Link to comment
jrock4224 Posted December 5, 2013 Report Share Posted December 5, 2013 So as a goon owner I'm familiar with the custom rear end options out there but has anyone here pushing 300bhp, lock-welded a h190 in a goon and had success for auto-x purposes? Or do the axels go out quickly with that kind of power? easy answer no .... tough answer if u can afford 300hp then u can afford a locker .. do it right Quote Link to comment
