sreams Posted October 17, 2013 Report Share Posted October 17, 2013 I just returned two sets of brake pads in a row to Autozone thinking they were manufactured incorrectly. According to this, the pad material is supposed to be cut at an angle: https://www.rockauto.com/catalog/moreinfo.php?pk=2044522&cc=1378065 How does this make any sense? If this is correct, which way do they go on? (two are angled one way and two the other way) -Scott Quote Link to comment
datzenmike Posted October 17, 2013 Report Share Posted October 17, 2013 It's normal. I think the caliper is hinged at one end and as the pads wear down they become parallel with the rotor. This is the driver's side of my 710. I think the 510s were the same? Maybe late 510s?? 1 Quote Link to comment
MikeRL411 Posted October 17, 2013 Report Share Posted October 17, 2013 (edited) Mike is right! These are for the the Akebono manufactured Lockheed Disc Brakes. The also came on the RL411 and first generation [1968 and on] 510s. They are indeed pivoted about one corner and when they reach the end of their life, the backing plated are parallel to the disc. Spread the backing plates and it will be obvious which tapered set goes on which wheel. Before you spread the plates and retract the pistons I recommend using an old soft bristle tooth brush to gently remove the builtup brake dust from the outside of the rubber boots. The boots are what retracts the pistons when you let off the brakes and removing the crud lets them work properly. Edited October 17, 2013 by MikeRL411 1 Quote Link to comment
datzenmike Posted October 17, 2013 Report Share Posted October 17, 2013 Wear a filter mask. I don't know what was used in the old brake compounds. 2 Quote Link to comment
datsunaholic Posted October 17, 2013 Report Share Posted October 17, 2013 Late 510s (A10) used normal (square cross-section) pads, same ones as the 210 (B310) and they were identical to Honda brake pads (and cross reference) of the same era. So I was a bit surprised when I got the "angle" pads for my '72, but sure enough that's the way they're supposed to be. Quote Link to comment
MikeRL411 Posted October 18, 2013 Report Share Posted October 18, 2013 Wear a filter mask. I don't know what was used in the old brake compounds. Lots and lots of asbestos! 1 Quote Link to comment
