DatMo Posted October 12, 2013 Report Share Posted October 12, 2013 So I bought a set of dual carbs for a great price although they do not air filters. I saw these and immediately fell in love. any one know what they are? or where I can get them? The backplate The filter assembly taken apart Quote Link to comment
EricJB Posted October 12, 2013 Report Share Posted October 12, 2013 Look like Ramflo's. Try Ebay. 1 Quote Link to comment
DatMo Posted October 12, 2013 Author Report Share Posted October 12, 2013 Look like Ramflo's. Try Ebay. they look like ramflo's but i don't know how to find a size or will they all fit? Quote Link to comment
datzenmike Posted October 12, 2013 Report Share Posted October 12, 2013 There isn't a lot of room between the SUs and the strut towers on any car. These will work but velocity stacks are the way to go. Some housings include the stacks inside. Quote Link to comment
Sealik Posted October 12, 2013 Report Share Posted October 12, 2013 ...." Stacks/air horns really only make a measurable improvement in the upper RPM range and wide open throttle (WOT)".... The problem is the distance between the rear SU filter and the master brake cylinder I have 46s with 2" air filters and 240 Z air horns...leaves about 1/2" from the outer lip of the horn to the air filter cover. This is the minimum amount of clearance for adequate air flow. Setup leaves approx 1" from the 510 MBC Quote Link to comment
Ratwagon1600 Posted October 14, 2013 Report Share Posted October 14, 2013 Send these guys an email, they should be able to give you a part no. http://www.lynxcorp.com.au/main.php?idx=home Quote Link to comment
