Need pics of 1975 oem battery hold down
dat521gatherer
  • Replies 4
I do not know if this will help, but a while ago, I repaired some battery hold downs I had from 521 trucks.  They would be really simple to make from scratch, or at least some cut up 18 ga sheet metal.
I noticed two types of corners on the hold down.  I call this a cap corner.
And this is an interlock corner.
I made a battery hold down by bending the steel sheet, clamped in a vice, between two other pieces of steel, because the jaws on the vice were not long enough.  All the cuts in the steel were just made with a 1/32 x 3 cutoff wheel, in an air grinder.
For hold down bolts, I took an old 3/8 nail, heated one end with a torch, and bent the end.  Then I welded a piece of 5/16 all thread to the bent nail, to make a "J" bolt.
For the loop on the hold down, that the bolt goes through, I just bent a small strip of 18 gauge steel around the all thread, and welded that to the battery hold down in the proper place.
