Sierra Posted October 9, 2013 Report Share Posted October 9, 2013 I would like to buy my B210 some rims but I am not very knowledgeable about wheels/rims upsets, + or – Anyone have a diagram or a range of sorts. Basically a guide I can follow in order to buy the right wheels. Ideally I would like to see my B210 on a set of 14" rims. Is this doable? Quote Link to comment
RatsunGT Posted October 10, 2013 Report Share Posted October 10, 2013 Very doable, mine has 13s on it. The bolt patterns 4x114.3 and I thought in a 1200 post the other day they can fit as large as 18x7. If its the same for the b not sure Quote Link to comment
datsunfreak Posted October 10, 2013 Report Share Posted October 10, 2013 Ideally I would like to see my B210 on a set of 14" rims. Is this doable? Quite. B) With stock front struts you want a 14x6 or 14x7 with a +10 to +15 offset. If you swap to 280ZX front struts/brakes you can use up to a +0 offset wheel. All of these you'll most likely want a 185/60-14 tire at either stock height or lowered 1-2". If you go lower, you'll need 185/55-14 tires to make it not rub in the front. Quote Link to comment
datsunfreak Posted October 10, 2013 Report Share Posted October 10, 2013 This is a 14x7 -9 offset wheel with a 185/60-14 tire, lowered 3" front and 2" rear, rolled and pulled rear fender lips. Quote Link to comment
vex210 Posted October 10, 2013 Report Share Posted October 10, 2013 Here are some for cheap just you'll need tires, 185/55 r14 good size tire on front.. http://losangeles.craigslist.org/wst/pts/4115948118.html Quote Link to comment
PineClone Posted October 10, 2013 Report Share Posted October 10, 2013 185/60R14 on 280zx wheels seems like a common alternative if you search the forum. Thats what i did (the 6-spokes) and they look good. And they give you options if you want to change things up (all aluminum, painted spokes, etc.). Quote Link to comment
Sierra Posted October 10, 2013 Author Report Share Posted October 10, 2013 Thanks for all the feedback. Keep those pics of your B210 coming (Great for inspiration) I love how datsunfreak B210 looks and thanks for the link vex210. I would like to keep the stock struts. So I might go with datsunfreak recommendation (14x6 or 14x7 with a +10 to +15 offset). I had at one point some aluminum wheels but they rub on the upper lip of the fender in sharp turns. Maybe I had the wrong tires on them. So I took them off (Dont know the specs of the wheels). What about using 13" wheels/rims? Changing the struts just to sport nice wheels seems a little to excessive to me but I am willing to consider it. If I go that road is there any adaptations I need to do in order to do the swap? Quote Link to comment
datsunfreak Posted October 10, 2013 Report Share Posted October 10, 2013 I would like to keep the stock struts. So I might go with datsunfreak recommendation (14x6 or 14x7 with a +10 to +15 offset). I had at one point some aluminum wheels but they rub on the upper lip of the fender in sharp turns. Maybe I had the wrong tires on them. So I took them off (Dont know the specs of the wheels). Those tires are a tad tall for that ride height. Stiffer springs would help. B) What about using 13" wheels/rims? You can definitely run the car lower on 13s, but the overall tire diameter doesn't really differ based on whether you are running 13s or 14s. It's really only an aesthetic choice. You can get both 13" and 14" tires in the same diameter and width. 14" wheels will just offer a shorter sidewall (firmer ride and "better" looks), so not much difference otherwise. Changing the struts just to sport nice wheels seems a little to excessive to me but I am willing to consider it. That's not why I did it... :rofl: I was offering you another option to consider if you just had to have deeper dish wheels. :thumbup: The reasons I did it was because it allows you to run a lower ride height, and it gets you MUCH bigger brakes. B) If I go that road is there any adaptations I need to do in order to do the swap? If you search around a bit you'll see what's involved. Just search '280ZX strut swap'. It's the same for almost any Datsun (except the 1200). There are no real "adaptations", just a minor modification to the spring seat of the 280ZX strut. It's about as close to a "bolt-in" as it gets. Side note, your front suspension is basically identical to a '68-73 510. So any strut swap/brake upgrade that you find that suits a 510 will also work for you. Quote Link to comment
