KlassicMotion Posted September 17, 2013 Report Share Posted September 17, 2013 '73 620 front fender: What hardware was originally used? The rocker is smooth behind the fender, no bolt or nut!?.... Quote Link to comment
datzenmike Posted September 17, 2013 Report Share Posted September 17, 2013 I think there should be a small horizontal slot (for adjustment) for a hex head screw fastener. Maybe two ? Quote Link to comment
]2eDeYe Posted September 17, 2013 Report Share Posted September 17, 2013 The bolt is broken off in the rocker, I can see it in your picture. Clean that area up a bit and you'll find it. You need to drill it out and tap it the hole back to 8mm x 1.25 thread. You use the same style bolt that holds the rest of the fender on. Quote Link to comment
Eagle_Adam Posted September 17, 2013 Report Share Posted September 17, 2013 damn, redeye beat me! those bolts break a lot.... Quote Link to comment
KlassicMotion Posted September 17, 2013 Author Report Share Posted September 17, 2013 Ahh, I see it now.... Man, this truck is giving me tons of bolt extraction practice :no: Five and counting. 6 more at least with the fuel tank mounting... Thanks, guys! Quote Link to comment
]2eDeYe Posted September 17, 2013 Report Share Posted September 17, 2013 Don't worry, you will get even more practice :thumbup: 2 Quote Link to comment
