71datsuns Posted September 10, 2013 Report Share Posted September 10, 2013 I need to replace my rear axle studs on my 521. I've gone to baxters, napa, auto zone almost all auto parts stores! Is there any place to get replacements? Or do I need to go to a junk yard? Thanks. Quote Link to comment
flatcat19 Posted September 10, 2013 Report Share Posted September 10, 2013 Pound a stud out and take it into the store. Don't try to look it up by application. Let the parts guy size it up. Dorman catalog will have tons of studs you can use. May need new lugs with it though. And if you're going that far may as well get longer ones too. Add 12 more studs and nuts to do the front too. Quote Link to comment
datzenmike Posted September 10, 2013 Report Share Posted September 10, 2013 Over $3 ea. at Nissan so smurf that. 1 Quote Link to comment
DanielC Posted September 10, 2013 Report Share Posted September 10, 2013 The studs that hold the wheel are threaded 7/16-20. This is an American SAE size. All the bolts for the body of the 521 are also SAE sized. 2 Quote Link to comment
KlassicMotion Posted September 10, 2013 Report Share Posted September 10, 2013 Pound a stud out and take it into the store. Don't try to look it up by application. Let the parts guy size it up. Dorman catalog will have tons of studs you can use. May need new lugs with it though. Do this^ Napa should have them. Failing that, do you have a Fastenal? Or with DanielC's info, look them up at summitracing.com. Quote Link to comment
flatcat19 Posted September 10, 2013 Report Share Posted September 10, 2013 Want to add, front and back have different knurling thicknesses. Quote Link to comment
71datsuns Posted September 10, 2013 Author Report Share Posted September 10, 2013 Yeah, I brought the stud to pretty much all the auto part store you can think of. One came close but the knurl was to thick. I haven't tried fastenal! Might do that today. Thanks guys! Quote Link to comment
KlassicMotion Posted September 10, 2013 Report Share Posted September 10, 2013 Wow, wouldn't have though that. Worse case would be Nissan like Mike mentioned. Someone correct me if I'm wrong, but I think the part number is; 40221-04101 Quote Link to comment
flatcat19 Posted September 11, 2013 Report Share Posted September 11, 2013 If they're just a hair too big, no stress. Get em! They're soft so they will squish into the holes in the hub. Extra stuck means extra awesome! Did you check the 521 pinned part thread for the ARP studs part numbers? :poke: Quote Link to comment
flatcat19 Posted September 11, 2013 Report Share Posted September 11, 2013 I'm wondering if these parts houses aren't able to find you studs because of the little notch on the 521's stud. I didn't do much searching because 1.) I don't have 521s anymore, and 2.) my parts houses are on it. But I did locate this... http://community.ratsun.net/topic/25695-wheel-studs/?p=369621&fromsearch=1&do=findComment&comment=369621 Quote Link to comment
71datsuns Posted September 12, 2013 Author Report Share Posted September 12, 2013 If they're just a hair too big, no stress. Get em! They're soft so they will squish into the holes in the hub. Extra stuck means extra awesome! Did you check the 521 pinned part thread for the ARP studs part numbers? :poke: lol. I was thinking about that. Wondering if that'd work... Baxters had one that was close, but the knurl was probably a 16th too big. I have not check that yet.... will do now thanks! I'm wondering if these parts houses aren't able to find you studs because of the little notch on the 521's stud. I didn't do much searching because 1.) I don't have 521s anymore, and 2.) my parts houses are on it. But I did locate this... http://community.ratsun.net/topic/25695-wheel-studs/?p=369621&fromsearch=1&do=findComment&comment=369621 Well thanks for researching a little for me. I appreciate it! I havent had any time to do anything. Work is slammed right now and when I get home all i want to do is face plant my couch.. Quote Link to comment
flatcat19 Posted September 13, 2013 Report Share Posted September 13, 2013 Funny. When I get home I want to plant my face in some cooch. Quote Link to comment
