fo0manchu Posted September 21, 2013 Report Share Posted September 21, 2013 whats your budget? i'm guessing if you are asking these questions then you are looking for a welder to learn on? I've had my lincoln for almost 10 years now, never skipped a beat. It was about $4-500 from Home Depot. Works great for hobby use. I also have a thermal arc tig, but i still use the lincoln for hard to get places and for a quick weld or tacking things up. To absorb heat on thin metal you can also use a copper or aluminum backing plate so it doesn't warp. Good luck and have fun! Quote Link to comment
KlassicMotion Posted September 21, 2013 Report Share Posted September 21, 2013 There are a few different products on the market for heat sink material for that matter: http://www.eastwood.com/ew-anti-heat-compound-1-qt.html Quote Link to comment
datzenmike Posted September 21, 2013 Report Share Posted September 21, 2013 I read Hot Rod magazine when a kid in the '60s. There was an article about a custom Thunderbird rear deck having a panel cut out and lowered and welded. They used wet cloths Quote Link to comment
91hrdbdy Posted September 26, 2013 Report Share Posted September 26, 2013 i own several welders i have a miller 140 for my every day small fab stuff. I also have a miller D.V.I. wire feed for my aluminum m.i.g. welding and thicker fab stuff. and i have a Miller dialarc 300 hf for all my t.i.g. needs now most home garages will be fine with just a miller 140 but i really would get a miller unit i have had my 140 in my shop being used every day since 2005 never had to to any thing but replace the expendables. its a really good unit and can be bought for less that 800 out the door. i felt the miller unit is far superior to the Lincoln counterpart and the have a feature called auto set for the learners and it work fairly well. Quote Link to comment
