NewKid559 Posted August 24, 2013 Report Share Posted August 24, 2013 I currently have a pretty clean 76 2+2 280z. It just got the top end rebuilt and runs good. Being that I'm 16 I want to go fast and since I dont make much money I thought I'd start attacking weight before I go for more power. I've been thinking lately and Im thinking about getting a 240z shell and dropping the L28 in it. I know the 240z's are a lot lighter so would that make them handle better? Is this reasonable? Are most parts compatible from the 280 to the 240? Thanks Quote Link to comment
Dattokai Posted August 24, 2013 Report Share Posted August 24, 2013 I'd go with 240z because it looks better and it's no smog. Quote Link to comment
M240Z Posted August 25, 2013 Report Share Posted August 25, 2013 240z is lighter and shorter than a 2+2, so they do handle better. A lot of the parts are interchangeable, but do your homework before tearing everything apart, and save some $ up. Quote Link to comment
ktm Posted August 25, 2013 Report Share Posted August 25, 2013 16 and you want to go faster in a car that has no ABS, no airbags, no traction control, and 40 year old components.....yah.....great recipe for disaster there. 240z's also have less structural reinforcement which is why they are lighter. As for handling they all handle generally the same, its more about the driver than the car. Don't be an asshat and rip your interior out in the name of weight savings. All it will do is make the car look like shit and be uncomfortable. 1 Quote Link to comment
Syncro Posted August 25, 2013 Report Share Posted August 25, 2013 ^this Personally I prefer the 2+2s, I've heard there more aerodynamic then the coupes. If you want the car to handle better upgrade suspension components, same goes for the motor and everything else. On top of all that you find a hell of a lot less 2+2s, even less in running condition, so when it comes to rarity there on par if not more rare then a 240z. Quote Link to comment
datzenmike Posted August 25, 2013 Report Share Posted August 25, 2013 You can't go fast all the time but you can drive all the time. Handling is the best fun you can have and in some cases you can out drive a faster car. Brake upgrade: http://drivendaily.org/s30-toyota-brake-upgrades/ This will likely increase the need for better tires to grip the road. Lower the car. Remove and cut coil springs. This has the benefit of increasing the spring rate as well OR replace with coil overs. Don't do this blindly, research. Lower car handles better in corners but has less ground clearance. Find out what bump steer is and how to correct on a lowered car. Go through the steering and suspension ball joints and bushings. Replace worn parts and know the disadvantages of polly bushings. Quote Link to comment
Spoona_Jay21 Posted August 26, 2013 Report Share Posted August 26, 2013 if you do the 240Z with an L28, you can just bring the BEAUTY of a 2+2 shell up here and it shall have a loving home. my dream Z is a 260/280 2+2.... Quote Link to comment
Syncro Posted August 26, 2013 Report Share Posted August 26, 2013 I've still got a 240z I'd trade for the thing. Quote Link to comment
Samson Posted September 1, 2013 Report Share Posted September 1, 2013 240z! Pre smog don't have to deal with all that BS. I see you're from fresno as well i have a 77 280z and it was a PAIN to get it to pass smog, but i did it. (: haha. Quote Link to comment
