Justin Posted July 28, 2013 Report Posted July 28, 2013 Got a sweet slider from the auto-dismantlers a while back, finally got my new gasket today, put it in and it looks like I will be needing ALOT of glue to make it work... So I'm ASSuming the answer is yes, but maybe not? Maybe something just got wonky? Inquiring minds want to know! :w00t: Quote
darrel Posted July 28, 2013 Report Posted July 28, 2013 rear windows were different between king cabs and standard cabs. Other than that, not sure if the same gasket can be used for a slider window on a non slider piece of glass. Quote
Justin Posted July 28, 2013 Author Report Posted July 28, 2013 That's cool, I knew that the king-cabs were larger. Snagged a re-pop gasket off e-bay, said it was for a standard cab (with no mention of the slider), guess that's the difference! I need a "slider" gasket- Bummer. Quote
datsunaholic Posted July 28, 2013 Report Posted July 28, 2013 Sliders were all aftermarket. Factory sliders didn't appear until the 720. The gasket for the slider was specific to each brand of sliding window, so generally if you find a window at a wrecker you need to get the gasket with it. Finding another may require buying another slider. 1 Quote
wayno Posted July 28, 2013 Report Posted July 28, 2013 I don't know about 620 rear windows, but the 521 sliders use a stock 521 window gasket, I cannot imagine that it would be any different on the 620. Quote
datsunaholic Posted July 28, 2013 Report Posted July 28, 2013 Some but not all use the stock gasket. Depends on the manufacturer. Quote
