PineClone Posted July 18, 2013 Report Share Posted July 18, 2013 I am THIS close to being done with my tranny swap! Can't start the car! Can someone explain how to bypass the neutral safety switch? Thanks! Quote Link to comment
bananahamuck Posted July 18, 2013 Report Share Posted July 18, 2013 You have a test light?? there should be wires hanging that used to be hooked to trans,, probably 4 wires total,, but only 2 different colors.. ook your test light to all of them one by one and the one that lights when you turn key to start is probably the correct one.. Hook that wire to teh wire that is most likely the same color ,, then try starting car with test light hooked to wire on starter to see if it lights,,, or hook starter up and test that way.. Quote Link to comment
datzenmike Posted July 18, 2013 Report Share Posted July 18, 2013 I'm guessing this is an auto to manual??? The interlock switch has back up light switch wires (two) that are usually Red/Black. The other two wires are the interlock, I don't know off hand what color the B-210 uses so what ever these other wires are, just bare the ends and crimp together and tape up out of the way. Quote Link to comment
PineClone Posted July 18, 2013 Author Report Share Posted July 18, 2013 Hooked a couple wires together and it started up. So i think i figured it out. Quote Link to comment
