cardkey98 Posted June 29, 2013 Report Share Posted June 29, 2013 only info i can find is Eltra 8355 and r8942 but the 2 is stamped over with a 1 http://s1349.photobucket.com/user/cardkey98/media/062813_195300_zpse2681fd9.jpg.html?sort=3&o=11 Quote Link to comment
metalmonkey47 Posted June 29, 2013 Report Share Posted June 29, 2013 Some kind of Weber. I don't remember what model. I've seen it before though ordered an air cleaner for a 32/36 once and they sent me a base plate for that carb. Quote Link to comment
bananahamuck Posted June 29, 2013 Report Share Posted June 29, 2013 It would be generically called a Holley / motorcraft 5200. oops thought i should add ,, it would have come on pintos up to early 80s mustang 4cyls and such Quote Link to comment
cardkey98 Posted June 29, 2013 Author Report Share Posted June 29, 2013 I do see motorcraft on side. I am guessing the Hitachi carburetor kit i ordered probably wont work on it. Any idea on were to get a rebuild kit? Quote Link to comment
bananahamuck Posted June 29, 2013 Report Share Posted June 29, 2013 Don`t know,, i had a few open half used kits from a million years ago when i circle tracked a pinto..and i don`t throw much away. Real parts store guys might be able to go through the holley book and find you something,,, cuz they are really standardized and used for many years, so parts should be there... If the counterman looks at it and doesn`t know what it is,,probably would be best to just walk out.. I just put -holley 5200 rebuild kits- into my browser and it came up with quite a few hits.. I have been running one since 2011 on my car so they do work and are cheap for me.. Outta my build thread... shameless plug i have edited this response so many times i think i'm confusing myself now. Quote Link to comment
datzenmike Posted June 29, 2013 Report Share Posted June 29, 2013 Holly jets will fit it and are cheaper than weber. Quote Link to comment
cardkey98 Posted June 29, 2013 Author Report Share Posted June 29, 2013 thanks for the info. I want to post pictures of the truck and rebuild but i don't know how to post pictures in the post other than through a link Quote Link to comment
bananahamuck Posted June 29, 2013 Report Share Posted June 29, 2013 Always use img code in the list of codes, If you click your user name in photobucket then select user settings,,,, then select Albums,,, then scroll down and turn on easy linking ,, the codes will appear under each picture without having to click gear symbol thing Quote Link to comment
Radim Posted June 29, 2013 Report Share Posted June 29, 2013 From what I know weber kits should work besides the top-half.These were sold under license through Holley/Ford/Motorcraft. Pretty much all weber crap besides the redesigned top. Quote Link to comment
cardkey98 Posted June 29, 2013 Author Report Share Posted June 29, 2013 I ended up buying the rebuild kit on rockauto. The kit was $27 closeout and there is 7 left if you might need one. I really appreciate all the help Quote Link to comment
metalmonkey47 Posted June 29, 2013 Report Share Posted June 29, 2013 Oh dang, I knew it was something close to a weber. Wonder how good this carbs actually are. Quote Link to comment
