lanechurch920 Posted June 14, 2013 Report Posted June 14, 2013 Hi I have a 85 720 and i am supposed to get a set of 20s for it and wondering what size tires will fit without rubbing? right now stock height, might tbar and block drop so nothing to serious Quote
Dawa Posted June 14, 2013 Report Posted June 14, 2013 not sure if troll.... 20s on a 720? what an abomination. here, this is a useful site to compare what youre running now to what you want to run. http://www.rimsntires.com/specs.jsp im not sure what the stock size for a 720 is, but for example if it were 195/75/14 (25.5" dia) then you might be able to run a 215/35/20 (25.9" dia, only .2" higher) (assuming they make thoughs, idk ive never had to buy 20" rubbers) Quote
datzenmike Posted June 14, 2013 Report Posted June 14, 2013 Hi I have a 85 720 and i am supposed to get a set of 20s for it and wondering what size tires will fit without rubbing? right now stock height, might tbar and block drop so nothing to serious So someone is giving you a set? Do you know the rim off set??? Because the rim may be too far in or out to use any size tire on it without rubbing. As Dawa said the stock 720 tire is P195/75R14 25.5" tall and 7.68" wide so a tire with similar dimensions should clear assuming the rim has a reasonable off set. A P195/35R20 is 25.37" tall and 7.68" wide. Again the off set is everything. Quote
mrbigtanker Posted June 14, 2013 Report Posted June 14, 2013 Dont do it please.Look up Donk and thats what you will be.Not trying to be negative but that is a lot of wheel on a small truck. Quote
lanechurch920 Posted June 15, 2013 Author Report Posted June 15, 2013 Ok ill just try and trade them for some 15s or something on craigslist Quote
Guss517 Posted June 15, 2013 Report Posted June 15, 2013 I believe u can get away w/ it if the rim isnt no wider then 8 in , ive seen one with 22's slamed!!& with the right tire!! Quote
mrbigtanker Posted June 15, 2013 Report Posted June 15, 2013 Ok ill just try and trade them for some 15s or something on craigslist Its up to you your truck,If you look at my truck i got 17's up front and 18's in the rear,now granted its a 521 but your 720 is not much bigger. Quote
