weber carb ??
Rasp933
Whats up fellas.
Iam currently running 32/36 weber on my l20b with no choke.
Ok now I thinking of upgrading it with 38/38 weber.now do I need to go with the one without any choke machical or electronic? And also will my old fuel pump work just rite wit it? Or do I need to swap a electric fuel pump too.
Any infos will b appreciated guys.thanx
  • Replies 8
if you have a 32/36 on there you just need the carb. The 38/38 is electric choke.
But you can adjust the coil wire the wire hook up and dial it back. You wont have a choke to use but the 38/38 works good on a L20 maybe rich , and esp on the L18/16s
stock mechanical pump is fine.
a Rastun discount is 100 for the carb but youll be in the 225$ range for carb only
