Rasp933 Posted May 24, 2013 Report Share Posted May 24, 2013 Whats up. Guys .rite at the moment I have my initial timing set at 12°btdc on a l20b.now how much advance is too much advance? Quote Link to comment
Guest_kamakazi620 Posted May 24, 2013 Report Share Posted May 24, 2013 Whats up. Guys .rite at the moment I have my initial timing set at 12°btdc on a l20b.now how much advance is too much advance? when it won't run...... Quote Link to comment
banzai510(hainz) Posted May 24, 2013 Report Share Posted May 24, 2013 how much advance is too much advance? till it pings!!!!!!!!!!!! Quote Link to comment
datzenmike Posted May 24, 2013 Report Share Posted May 24, 2013 What Hains said. It depends on compression, fuel octane, air temp and humidity, altitude, engine temp, fuel mixture and probably a few others. The L series is designed to run at or around 12 degrees but the variables listed above can move this up or down slightly. If your car runs well at 12 then good enough. It's not always a good idea to crowd the pre ignition point. Quote Link to comment
Rasp933 Posted May 26, 2013 Author Report Share Posted May 26, 2013 Yeah It runs good at 12° Quote Link to comment
