DREWSDIME Posted May 15, 2013 Report Share Posted May 15, 2013 I have 85 720 xtra cab and installed tach and clock today it was pretty easy and thought i would post how to. I only needed a few tools - phillips, flat head, drill with small drill bit. I would remove your steering column cover so you dont scratch yours like I did. First remove your steering column cover!!! Then remove plastic trim 2 phillips screws at top and 2 clips underneath cluster (just pull and it will pop out) Then 4 phillips holding cluster.Next remove metal cover under steering column 4 phillips and 2 larger phillips or 10mm socket. Next reach up under dash behind cluster on left hand side of steering column and you can unplug speedo cable has clip on top you just press on cable will slide off also 1 plug on left side of cluster just squeeze both sides of plug and it will pop out. Now you can get some mor eplay on cluster and slide your had behind ride side and unplu 2 other plugs smae way just squeeze both sides . Now you cn slide cluster out farther and there is 1 more tiny plug on right side. clean it while its out Next up with flat head push tabs in and cluster will come apart Now you unscrew block off plates Quote Link to comment
DREWSDIME Posted May 15, 2013 Author Report Share Posted May 15, 2013 Pretty simple clock goes here with 2 screws Quote Link to comment
DREWSDIME Posted May 15, 2013 Author Report Share Posted May 15, 2013 Tach goes here but I had to drill 1 small hole for other screw Quote Link to comment
DREWSDIME Posted May 15, 2013 Author Report Share Posted May 15, 2013 Ok this is pissing me off, cant post more than 1 pic at a time Quote Link to comment
DREWSDIME Posted May 15, 2013 Author Report Share Posted May 15, 2013 Had to drill a small hole for clock push rod. Hole was marked on glass from the factory Im assuming Quote Link to comment
Draker Posted May 15, 2013 Report Share Posted May 15, 2013 Nice work! I did this not too long ago. I'll see what I can come up with on the intermittent wipers and post it up in my build. If you beat me to it.. let me know!! lol Quote Link to comment
TENDRIL Posted May 15, 2013 Report Share Posted May 15, 2013 is that a rear disk bracket ? :sneaky: Quote Link to comment
DREWSDIME Posted May 15, 2013 Author Report Share Posted May 15, 2013 is that a rear disk bracket ? :sneaky: Im assuming your talking about the billet bracket in the background? Thats for my 510 to put 240sx disc in the rear, just traded some parts for them and drilled rotors Quote Link to comment
mrbigtanker Posted May 15, 2013 Report Share Posted May 15, 2013 Im assuming your talking about the billet bracket in the background? Thats for my 510 to put 240sx disc in the rear, just traded some parts for them and drilled rotors Looks like Juan did a deal with you. Quote Link to comment
DREWSDIME Posted May 15, 2013 Author Report Share Posted May 15, 2013 Yeah he made me an offer and I took it. Since my 510 is getting KA swap I have spare rear cross member Im trying to upgrade before swap is done. Looks like Juan did a deal with you. Quote Link to comment
