VG30et swap
rus
  • Replies 33
^^^ This is awesome !!! :cool:
Keep up the good work. rus ...
ouch.. I was lucky enough to have a friend with a z31 turbo that recently blew a tranny.
Well L28et is quite fun as well, I almost did a vh45 swap but needed custom headers and not enough money.
I'm surprised I got all the wiring right. :confused:  This was my first time wiring an engine.
That's impressive on the vh45 wiring...
custom headers sounds like a @#$@# and a duece..
Thank you! B)
Yup and there was barely any room for them there
And I'm pretty sure car would handle better with VG than with Vh45
  • 1 month later...
Well it's been a while. I couldn't work on my z for over a month but now I'm finally back at it.
No major updates, just started to organize and clean up engine bay.
Tested WG actuator, which is a stock z31 actuator modified to fit, for some reason it starts to open at 10psi and fully opens at 14.
I guess the spring was damaged by heat when we welded the rod.
  • 4 months later...
Since stock crossover pipe was right next to stock 280z brake lines I had to reroute them.
Bought a roll of brake line and rerouted all of the brake lines in the engine bay, including clutch line.
Put the brake booster and downpipe back on only to realize that downpipe is touching the brake booster...
I guess the brake booster I got at the junkyard is either slightly larger or shaped differently than the stock brake booster.
great job on the swap!  I'm in the beginning phase of mine and have the wiring and a few other things worked out but I was curious as to how you actually mounted the motor.  Did you fabricate motor mount brackets or use some modified mounts from an obscure car?  Some pics would be greatly appreciated as well!
