'72 510 ball joints
  • Replies 19
Every ones right, this is not a hard job.
Trick is to jack the car up high enough so you can get decent downwards leverage on the control arm
Use jack stands! And place them under the chassis rails.
This is the post size you want.
7ac3789f7693c5254ade9efacc124f1a_zps1910
Post if you need more info.
Not necessarily,my 71 has 11 mm on it.I ordered 14 mm and had to send them back.
Unusual, but certainly not unheard of.
Down here, the cutover year for the change in ballpoint size was for the 70 model 510
I guess there are rare cases where they are different, but 70+ should be 14mm. Maybe at some point someone swapped your control arms to early units John.
  • 1 month later...
