73' 620 Rear Drop question...
Fuelrags
Hey Guys,
I need your input on a little discussion I overheard at the Datsun Pickup section at a recent show. First of all I installed 2 inch Blocks in the rear thinking 3 inches would be too much,come to find out that 2 inches is not nearly enough! I heard that removing 2 leafs out of the rear equals a full inch of drop,(not to mention by removing the 2 lower helper springs gives you a gain of clearance of the lower shock plates). Have any of you experimented with this? Thanks,Martin
  • Replies 9
When I 1st lowered my 620 my leaf pack had 5 leafs...
I removed the middle 3..........
& then later added a 3 inch block & it sat like this...
At this point the axle was close to the frame & would bottom out alot [bumpstops removed]. How many leafs does yours have now? If you do remove any make sure to leave the thick bottom one & plan on replacing the bolt that holds them together [grade 8 bolts] & youll need to round off the heads. Remember too that this will lesssen your payload but if you dont haul anything it's not really an issue.
I pulled out the second shortest leaf the other day and it really did NOT do much. Seems to have settled since then with driving, but at most 1/2 inch. Definitely LEAVE the big support leaf at the bottom! If you EVER haul anything without it...you will wish you had left it. I plan on going back into it for the next longest leaf.:)
HOW WAS YOUR RIDE QUALITY AFTER WITH ONLY 2 LEAFS???
Well it was alot less stiffer than before & rode ok. But...the frame was close to the axle & would smack it on big bumps. At that point a 2 inch block would have prevented that but i wanted to be as low as possible:D
