STOMPIN A TOAD Posted March 18, 2013 Report Share Posted March 18, 2013 Ok this is what I got- L16 block and intake for weber down draft and of course an L 20 head. I have two questions. The intake ports for the intake are way smaller than the ports on the head. Should I just leave it or try to port match it to the head? Question 2.. What is the deal with the sleeves in the exhaust ports on the head? Iv'e never seen anything like that before. When I lap the valves and clean up the head should I keep the sleeves or lose them? I'm not going for lots of power but I take it where I can get it. Quote Link to comment
bludestiny Posted March 18, 2013 Report Share Posted March 18, 2013 If you mean sleeves as in metal fin looking things built into the port, then they are for emissions (if its the same as the later L28 heads). The runners get really hot and burn off extra crap in your polluting exhaust. I've heard they are a bitch to remove, but I've also seen people just do a complete port job on them and they look just the same. If you want to leave it practically stock then just leave them be. The only time I've heard any horror stories is when someone ran a turbo with a head like that and it got got and a chunk went into his compressor. Quote Link to comment
datzenmike Posted March 18, 2013 Report Share Posted March 18, 2013 First it's not a good idea to run an L20B head on a smaller L16. The correspondingly larger combustion chamber will lower your compression to 7.72 from 8.58 and make it sluggish. Better would be a closed chamber head or best, the stock 210 L16 head. You have a W58 head marked between the #1 and #2 spark plugs down low. These have round exhaust ports and don't match the stock L16 exhaust manifold BUT you can run it that way using an L16 gasket. The metal sleeves inside are held away from the cooler port walls so they will heat up orange hot from the exhaust. This will ignite any unburnt fuel and reduce emissions. Quote Link to comment
STOMPIN A TOAD Posted March 18, 2013 Author Report Share Posted March 18, 2013 If you mean sleeves as in metal fin looking things built into the port, then they are for emissions (if its the same as the later L28 heads). The runners get really hot and burn off extra crap in your polluting exhaust. I've heard they are a bitch to remove, but I've also seen people just do a complete port job on them and they look just the same. If you want to leave it practically stock then just leave them be. The only time I've heard any horror stories is when someone ran a turbo with a head like that and it got got and a chunk went into his compressor. I figured that it was for emissions, but this is Iowa ha ha ha ha we don't care about emissions!! :rofl: Anyway I don't think i'll do anything big like pistons or turbo....This time around. Quote Link to comment
Z-train Posted March 18, 2013 Report Share Posted March 18, 2013 I figured that it was for emissions, but this is Iowa ha ha ha ha we don't care about emissions!! :rofl: Anyway I don't think i'll do anything big like pistons or turbo....This time around. Doesn't matter-that head is still completely wrong for your application. Quote Link to comment
STOMPIN A TOAD Posted March 18, 2013 Author Report Share Posted March 18, 2013 First it's not a good idea to run an L20B head on a smaller L16. The correspondingly larger combustion chamber will lower your compression to 7.72 from 8.58 and make it sluggish. Better would be a closed chamber head or best, the stock 210 L16 head. You have a W58 head marked between the #1 and #2 spark plugs down low. These have round exhaust ports and don't match the stock L16 exhaust manifold BUT you can run it that way using an L16 gasket. The metal sleeves inside are held away from the cooler port walls so they will heat up orange hot from the exhaust. This will ignite any unburnt fuel and reduce emissions. You got to go spoil my fun don't you. WHAT IF?? I put in some pistons out of an L24? Do you think that would compensate for the bigger combustion chamber? Oooh Maybe I could mill the head. Actually I don't wan't to mill the head or put in different pistons, but I would like it to be snappy. I guess I should see if I can find a 210 head. Quote Link to comment
STOMPIN A TOAD Posted March 18, 2013 Author Report Share Posted March 18, 2013 Doesn't matter-that head is still completely wrong for your application. I know but it's all I got. Quote Link to comment
datzenmike Posted March 18, 2013 Report Share Posted March 18, 2013 One man I got the number wrong it's it's.... (wait for it).... 6.72 sorry. L24 pistons would bring it up to ..... uhhhhhhh.... 7.63. Quote Link to comment
STOMPIN A TOAD Posted March 18, 2013 Author Report Share Posted March 18, 2013 One man I got the number wrong it's it's.... (wait for it).... 6.72 sorry. L24 pistons would bring it up to ..... uhhhhhhh.... 7.63. Oh my god well I guess I could always just put in a hamster wheel instead of an engine. :w00t: Quote Link to comment
datsunaholic Posted March 18, 2013 Report Share Posted March 18, 2013 Well, you certainly won't have to worry about pinging. Though the ~15 MPG you might get with that low of compression might be an issue... Really, you need a closed-chamber A87, W53, or just a stock head. Folks almost give away stock 510 heads. Quote Link to comment
STOMPIN A TOAD Posted March 18, 2013 Author Report Share Posted March 18, 2013 Ok then does anyone have an L16 head they want to trade for an L20 head? Or perhaps just sell str8 up? Quote Link to comment
datzenmike Posted March 18, 2013 Report Share Posted March 18, 2013 Shall I move this to Parts Wanted??? Stock L heads are just under 40 pounds. Less if you have the seller remove the cam and rockers. Use the W58 cam and rockers. The L20B cam is almost exactly the same specs as the L16SSS cam. Quote Link to comment
STOMPIN A TOAD Posted March 18, 2013 Author Report Share Posted March 18, 2013 Shall I move this to Parts Wanted??? Stock L heads are just under 40 pounds. Less if you have the seller remove the cam and rockers. Use the W58 cam and rockers. The L20B cam is almost exactly the same specs as the L16SSS cam. Naw I move it, I got more stuff I need. I'll put it up when the $time$ is right. The 210 head doesn't have the funky exhaust ports does it? I'm definitely keeping the cam though. :hyper: Quote Link to comment
